- 29 Aug 2010
- Cornwall
I've recently re-done my watercooling for the 3rd time.
I've gone from:
CM 690 II
240mm XSPC RS rad
240mm EK rad
Gigabyte GA-880GM-UD2H
Phenom II X6 1055T @ 3.5GHz with HeatKiller 3.0 Cu CPU block
4870x2 with EK 4870x2 block
Swiftech MCP35X fitted into a XSPC dual-bay res
Feser Bi-distilled water
4 x Akasa Vipers (usually running at ~1300rpm)
To a:
CM HAF 932
360mm Black Ice SR-1 rad
120mm EK rad
Asus M5A99X EVO
GTX 480 with XSPC 480 Razo full-cover block
Mayhem Red Pre-mix fluid
4 x Gentle Typhoon AP-15 (running at around 900-1000rpm)
My temps previously weren't fantastic but weren't bad (CPU low 40s under load, GPUs ~50ºC while gaming or running Heaven), it was just a bit noisy running Vipers at ~1300rpm and probably a bit higher when under load.
Now my temps are worse! My CPU was hitting 48ºC after 90mins of Prime 95 SFF and the GPU hit 55ºC after 1 run of Heaven.
Why did my temps get worse?
The air coming out of the rads is cool and the dual-bay res is cool to the touch, previously the water in the bay res would get warm as would the air coming off the rads.
The GPU block looked to have good contact after I fitted it (I might have put a smidge too much TIM on it) and the CPU block doesn't seem like something you can really mount wrong, unless I used too much/little TIM, but it was about a pea sized amount.
I used ICDiamond24 on the CPU and Arctic Ceramique on the GPU (didn't have any ICDiamond at the time and didn't want to use AS5 as I wanted something non-conductive).
Anyone got any ideas as to what's not right?
Thanks in advance for any help.
I've gone from:
CM 690 II
240mm XSPC RS rad
240mm EK rad
To a:
CM HAF 932
120mm EK rad
Asus M5A99X EVO
