would you say i would get better quality with two hdmi's using one dvi to hdmi adapter?
The Asus VS247H has DVI-D & HDMI inputs
I presume your GTX560 has DVI+DVI out or DVI+HDMI out
Grab yourself a DVI to HDMI cable.
e.g. http://www.overclockers.co.uk/showproduct.php?prodid=CB-018-OK&groupid=1929&catid=1753&subcat=
That can also be reversed if you want it HDMI to DVI.
i know the motherboard has a hdmi slot but will that only use the onboard graphics card or will it use the gtx ?
and will there be no problems with my gtx 560ti using two monitors?
that's a really good point actually, so its either 3 monitors or 1 for gaming. i do a lot of video rendering and editing so that's why im after two monitors. is there a way i can use both for editing/general pc use and then switch it back to just the single monitor for when i game?
You can run up to 5 from special edition GTX 560ti cards
http://www.bit-tech.net/hardware/2011/09/02/editing-kfa2-mdt-x5-gtx-560-ti-1gb-review/1
Not so good for gaming, and you need DP monitors
