Revised Silencio RC-550?
20 Oct 2008
I was half considering getting a Cooler Master Silencio RC-550.
Having read various reviews I’ve seen mention of a slightly modified version of the case with, amongst other things, different sound deadening foam on the right-hand side panel and at least one additional cable management hole.
Does anyone know if the revised version of the case is out there and available? If it is, is there any easy way to identify which version is for sale (different part # perhaps)?
I emailed Cooler Master about this about a week ago and haven’t had a reply.
Thanks.
Seen a review, it is not pretty, the case is more for media centres then gaming.
The stock fans are said to be dire...
Check out CCR's review on You tube.
Cheers
Von
Cheers
Von
It's designed to be as quiet as possible and is perfectly capable of cooling a high end system, it does what it was designed to pretty well.
