Unfortunately not, i wish there was!
If they follow it up with an expand, just move your couple of roaches out, block the ramp with your queen and expand yourself... obviously you'll need more than 3 roaches for this, 5-6 should be okay, with a couple of lings as a meatshield. wherever possible keep them grouped or with their backs to the wall to avoid ling surrounds. Banes don't do much to roaches, so unless they have invested heavily in them, this strat should be alright
alternatively, invest heavily in roaches, and take out their expansion. This is very "All-In" but can really throw them, especially if you only reveal your blocked ramp to them with only 3 Roaches,.. the other 8 are hiding near your hatchery out of sight
not showing them your army/composition is very important!
If it works, then once the expo is dead, make your own and pull your roaches back to your base, your then ahead in economy and in army!
no worries, with the drone trick, you need to see it coming as it can take quite a while (especially at first). so overlord placement needs to be good too![]()
Hmm, all interesting food for thought, thanks for the help
. I guess maintaining a wall is much more important than I thought...
Hopefully it will help make same race match-up's more bareable as well.
