*** Official OcUK Minecraft Server - Discussion and Rules ***
If your name is "Russ" on linktart you need to join the Minecraft group and under that click on Minecraft Server then Register too add your Minecraft username :)
Also to everyone else:
New Cartography!
http://linktart.co.uk/blog/cartography-26092011/
Can you tell Tefal has been on?! :p
If your on about the lonnng run from spawn, that wasn't tefal taht was me :D
Spent 40-50 minutes running in one direction (well, not quite one direction, seems i turned off at one point) got myself 43 pumpkins from that run!!! considering i'd never seen pumpkins before in 1.7 and prior i was fairly chuffed :D
EDIT: on another note: LOVING the multiple home settings, i've got about 5 home locations along that stretch with tefals new home being home 4 (if anyones able to go to it, do so, its amazing)
thats what i mean.
I like the share home system and would not mind having limited homes of 4/5
as i tend to build large projects walking from one end to the other is a pain sometimes :P
Can anyone post the new home commands please, trying to work out how to do multiple homes :) thanks.
/sethome 1
/sethome 2
etc
/home 1 takes you to home 1 and so on
EDIT: well, your first home you can just do /home, but for subsequent ones /home 2 etc works
I've never been a fan of having infinite homes, reminds me of the old days of having warp points..
I miss the public-ness of the old plugin, and it would be nice to have 3 or 4, but as yrth says, what we have is what we have :)
If the old plugin is ever updated properly I'll possibly move us back to it. It would mean losing your current homes though.
noooooooooooo
I <3 the multi homes too much! Although i can see why it could be disliked :D I have a home in a swamp, home in a desert, a home as far away as i could run, and a home in each village i came across on my travels lol mainly for ease of collecting resources.
I guess in an ideal world we'd be locked to 2 or maybe 3 home locations though.
IMO it does start off good having so many, but then when you can warp all over = the entire map instantly it does get a bit old and starts to lose the fun element.
But with all the updates (MC and Bukkit) and 1.9 possibly out even today it might well be a case of having whatever plugin works, as FT says :)
I dont know if you realised but you dont have to just number home points, you can name them so say /sethome treehouse or /sethome spawnhouse
hey just to get things cleared up before yet another argument happens.
When MC retail is released are we getting a map wipe?
I want to know as there is argument that maxi and FT said they will try keeping 1.8 map for retail. But i must have missed that as i thought that was only for 1.9.
So to clear it up once and for all FT are we getting a wipe or not?
I ask manly because i want to know if i can start working on a project or not.
I'll just be content when they fix the damn door big. I put double doors on my home and it's a nightmare getting in and out.
I don't mind the home spawns, as it's easy enough to limit your own use of them. I use them in deep mines etc because I just can't handle the stress of losing my stuff...again! So when i collect a nice amount of things i tend to spawn out, and back again to store them just in case.
Hehe, i was mining yesterday and emerged into a large staircase going up. I went up and destroyed walls, water flooded in so i went up some more and it turns out i'd tunneled into a mine my friend had created from his basement then blocked up. I had to rebuild his basement and block the water back off. Ooops.
We've not stated that we're keeping the 1.8 map for retail. We've said we'll probably (not definitely) keep it for 1.9 however.
At retail a wipe is the most likely prospect. However, this is still under consideration.
