New PSU?
7 Jul 2010
Hi,
Recently upgraded my PC but didn't upgrade the PSU at the same time.
I bought.
I5 2500k
8GB of Kingston HyperX Genesis Grey
Asus P8Z68-V
Crucial RealSSD M4 64GB
1TB Samsung Spinpoint F3
I have a feeling my current Cooler master 550W PSU will be on the limit when I come to add a decent graphics card? (560TI, possibly higher)
What's the general opinion?
Thanks
Which CM PSU is it? age?
I think you should be fine with a GTX560ti/6950 and a 550W PSU.
Any higher or SLI/Crossfire then a new PSU will be nice.
This PSU - http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-AN&groupid=701&catid=123&subcat=1088 - is good for any single graphics card and SLI/Crossfire of GTX560ti/6950/6970 etc.
This one - http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-LA&groupid=701&catid=123&subcat=2057 - will manage a pair of GTX570 SLI and the lesser cards
This one does GTX580 SLI and all the lesser cards - http://www.overclockers.co.uk/showproduct.php?prodid=CA-039-OC&groupid=701&catid=123&subcat=1098
The sticker looks slightly differnent.
My product number is RP-550-PCAA-E2, that one seems to be RS-550-PCAR-E3
That could mean the one you linked is a newer, improved version which is equally as bad.
Yup - bin the PSU. Buy an efficient model and the 10% extra efficiency will probably pay for your replacement over the next couple of years.
The PSU geniuses on here will be able to recommend a good buy. I would recommend the XFX core edition 550W / 650W / 750W from personal experience depending on your future power need.
Stulid - quick question. What is the basis for the power requirements you're suggesting? I only ask because depending on whose opinion you listen to, total power consumption, even for a beast of a machine with twin cards, rarely seems to exceed 600W.
Bloomin eck! Just seen the Furmark power draw on 580 SLIs from your second link (850W !!) - I stand corrected.
I wonder how many PSUs Furmark has wrecked... :)
Cheers for the reply Stulid.
I'd get something beefier for that. Lepa 850W looks minimum (750W on 12V). XFX Pro 850W, Corsair TX850W, or that OCZ Z-850, but... it's OCZ athough the builder is Sirfa / Sirtec. Then you'll have plenty of headroom.
Just like you'd use a 750W PSU for a 560ti / 6950. Although a 650W will work with those as long as you don't go overclock silly.
Ok thanks.
What 850w PSU for around £90-£100 do people recommend?
The OCZ Z-850 is the one I seem to be leaning towards, seems to get great reviews.
