so does anyone know when we will get the early access emails (moh le and alpha tester here )
yep am the same got the moh le box sitting in front of me and theres a ticket inside that just says bf3 is coming, i think its somthing to do with the moh serial key but could be totaly wrong"In order to qualify for Early Access you must have played Medal of Honor Tier 1 or Limited Edition online and redeemed your Online Pass, or you must have pre-ordered Battlefield 3 via Origin before the 25th of September."
Can someone please tell me what 'redeeming your online pass' means?
I can't seem to find out anywhere! I've registered my copy of MOH:LE after playing for about 4hours [it was *****!] but dont remember doing anything else with it..should I have done something else?
thanks
2.somthing gig if i remember rightlycant wait, sadly running out of space on my ssd! alpha peeps how big was/is the install?
Seen the LE for £29.91, anyone else cheaper for physical or digital LE versions?
Yeah I keep seeing the phrase 'reedeem the code' but nobody seems to know anything about it.
I might have to reinstall MOH again *shudder* and see if that tells me anything..
Quite a lot of options for the beta then.
