Chrome's new tab page
7 Nov 2005
Southampton, UK
Arg, I hate it!
There's now three pages in one.
Most Visited
Apps
Bookmarks
Most Visited and bookmarks used to be on the same page, bookmarks are a menu and bar in place of the bookmark bar).
The bookmark tab now drills down into your bookmarks, so there loads more clicks when you have spent ages organising your bookmarks into folder.
Apps, what the hell are these? I installed the google calendar one, you know what it is? A bookmark to calendar.google.com!
Lastly, when you've drilled into your bookmarks, you get a breadcrumb trail at the top. Great, except you can't click the text to move up the trail, you have to click the white space between the text and the box around the text.
Massive fail Google. Massive fail.
Anyone got another opinion on this or seen things in it that I haven't?
The absence of the "recently closed" bit annoys me, but other than that I'm not too bothered, I always use the bookmarks bar anyway, and I don't have any apps.
i like it but probably use it a bit different to you.
friggin love the way everything syncs across my lappy and computers and would pu up a fair amount just to keep that :)
er, mine hasn't changed much except it has an "apps" section. All I did was minimise it and the page is back to the way it was with "most visited" being the larger middle section and "recently closed" along the bottom as normal.
No idea why you are raging. I spent 10 seconds to get it back to the way it was... Maybe try something similar?
