I just want to say, the new log in screen looks Awesome
Yes, yes it does.
Having Mumble login issues again, it won't accept the correct password.
Would me logging in from my gf's laptop and now from my own machine cause an issue?
Also, not sure if it has been mentioned but: http://euw.leagueoflegends.com/youtube
subscribe to the riot youtube channel through that link and you get a free unchained Alistar skin.
Not true now with normal draft - as rogue blade so eloquently put it, people get far to into their stats and when it doesn't go right they rage because their stats are everything![]()
Jesus 4 losses in a row today. Either I'm total **** with Vayne or matchmaking hates me (2 leavers and an afker).
FRUSTRATION AHHHH!!!!
I did this and got Alistar free as well!! Not sure if that's meant to happen but I can definitely choose him on the champion screen before a game...
Not true, and if people rage at you in ranked, behind the bluster there is a good chance you are doing something wrong. The rage is not about the stats, its about noobs playing outside of the meta and screwing things up![]()
Any fancy some games now if there bored?I'm not amazing but not terrible
Yes, it definitely would. Mumble stores a certificate based on your PC so you would be conflicting with it's file structure if you tried to log in from 2 different machines with the same username, without transferring your certificate of course, and would encounter the same problems as if I had tried to log in under the registered username Kr00t0n. Just use 2 different names for both machines and you'll be fine![]()
Thanks for the mate, I think that is still one of my key problems with LoL is my want to jump in and fight, it's exciting, it's fun but the main thing is I don't want to see my team die while I just chill out and hang back but you're right I need to do that. I've started to with Fiddlesticks a lot more now and have noticed a much improved play style with him, I just think I need to adapt this play style with others; been a hard transition from Tanky DPS solo top to slightly squishier junglers.
You can poke with your q, and attack if they run into your team but if you jump slap bang into the middle of their team as soon as you are in range you are just giving them a free kill... basically the thing to learn is that as great as his ult is it is never to be used as an initiation in team fights as the 3 seconds it takes for the rest of your team to catch up with you is plenty of time for them to kill you and regroup for the rest of your team.
This is why i build him aggressively most of the time.... if you get focused you will die regardless so may as well not bother, rely on a banshee's and your own w to keep you alive, if you take more than 2 nukes then its time to run away
Hmmmmm BF3 beta has kinda taken over my nights....
