Would my system run FSX
Permabanned
14 Jul 2011
Starship Enterprise
Athlon II X2 255 @ 3.3Ghz
4GB DDR3 1366mhz Corsair ram
MSI 460GTX 1GB
Win 7 ultimate 64 bit
Enermax Lepa 500W
On high/highest settings?
What about crysis and COD too, will it do that on high?
I have a 1280x1024 monitor
From everything I have read about FSX, you could have the most amazing rig currently available you are still going to to struggle.
it needs serious tweaking on each PC and has quite a few issues.
Search for it on here and you'll find a link to a dedicated forum for it where they help set up rigs to play it.
It would play FSX, but not sure about highest settings! Should do on CoD, but deffo not on Crysis unless you are happy playing at 20-30 fps?!
Mine defaults to "Ultra High" with my spec in sig, so the OP should get reasonable results with his.
Tweaking tweaking & more tweaking is the key.
I have just bought a i2500k and 8 gig mem and I can run it on Ultrahigh settings using FTX Tasmania addon. (recommended just so see what and addon can do).
I only have a crappy 4870 so I'm not even going to attempt heathrow on ultrahigh lol
However flying from small airfield it looks stunning.
i'm going to get a new gfx card and then start seriously getting into FSX again...
No what?
No you don't like flying? or No you think Crysis is a graphically pretty but ultimately crap "OMG I must buy a £500 GFX card to see it running well" piece of crap that is really a benchmark that your supposed to play?
Or, is it just plain No as in no, I'm not?
In which case, what are you?;)
