Hi folks,
Thought I'd make a thread here in case someone may be able to shed some light!
My old 2000 Honda Accord 2.0 (my Dad has it now) has, since I've had it (and has done for years) a slight 'flat spot' at exactly 2,500RPM when under load, noticeable in lower gears, but mostly in 2nd and 3rd. The symptoms are if you're accelerating hard, i.e. WOT from low RPM through the revs, you'll feel a slight jolt as it passes 2,500RPM.
It didn't bother me as it's not THAT bad but my dad is very curious.
We've tried everything we can think of, including:
New plugs
New leads
New fuel filter
My dad took it to Honda who spent 4 hours looking at it (but don't worry, they didn't even charge him an hour's labour) and said that the distributor cap/rotor are fine, all the sensors are fine, all vacuum pipes are fine, nothing appeared on any diagnostic equipment. They don't know what to suggest without spending god knows how many more hours investigating.
It's had pretty much every other consumable part I can think of! Even a new clutch, although I'm sure that's not relevant
We're out of ideas! My only remaining theory is that it's something to do with the engine management and some sort of mapping discrepancy, but I'm not sure what can be done about that.
Anyone?!
Thanks!
Edit: FYI, it's a 2L SOHC 16V VTEC engine.
New plugs
New leads
New fuel filter
Anyone?!
Thanks!
V-TEC usually kicks in around 6000 rpm mark, but I have no knowledge of this engine so can't comment!
No rattles, the engine runs absolutely perfectly otherwise
