Does anyone know when the MSI Z68A-GD55-G3 will be released? It's on preorder just now. I want it because it's a lot cheaper than the other sata 6Gb/PCI-e 3.0/ivybridge ready boards
WEll looks like it's been released.
What's the difference between the GD65 and GD55 then apart from the number of SATA 6Gb/s ports?
EDIT: Ah... 2x16 vs 1x 16 1x 8.
Slots
• 2 PCI Express gen3 x16 slots
• 3 PCIE x1 slots
• 2 32-bit v2.3 master PCI bus slots.
- Support 3.3v/5v PCI bus interface.
Slots
- PCI_E2 supports up to PCIE x16 speed
- PCI_E5 supports up to PCIE x8 speed
• 3 PCI Express gen2 x1 slots
• 2 PCI slots
None of these boards will be 16X/16X, the slot maybe a physical 16X in length, but the connections from the cpu socket/pci-e switches wont.
Most boards are 8X/8X or 16X/4X, only boards with a NF200 chip costing hundreds+ will offer more.
Of course, but what happens with the GD45 is even if you put a single card in the 2nd PCIe 16x length slot you will still only get 8x, not that it matters much and as you say for crossfire you'd still get your 8x/8x so not really an issue either way.
GD55 and GD65 are separated by the Marvel controller and Dual BIOS
It doesn't though?![]()
