Monitor size?
10 Feb 2010
I am looking for a monitor for my soon to be new computer, but am not sure what size I should be looking at. I am looking between 22"-24". A bit of a general question, but which is better?
22" used to be sweet spot of pricing vs utility last year, but now most of the factories are flooding the market with 24", which is now the best price/performance. From the massive drop in pricing of the 27", that I hazard a guess will be the sweet spot next year or year after.
I'm not so sure that's true, 27" at 1920x1080 is just not a nice as a 24" imo, however if you can afford to buy something like the Dell U2711 which has a resolution of 2560x1440 then ...maybe yea.
I consider 22-24" to be the best place to be, unless you can afford to buy the high res IPS 27-30" displays ...however consider that for that kind of display you need a bit more space too.
24" it is then. I have seen a lot of 24" actually be 23.6", except BenQ. Which is the best 24" for around £150-£180?
For that price, unless you specifically require lots of extra inputs, the LG IPS231P-BN is the best display you can get, it's a vastly superior IPS panel rather than a TN. Until this LG came out, it was preciously unheard of to get an IPS display for much less than about 250 pounds. Also don't undervalue the usefulness of a height adjustable stand (not relevant if you have a VESA arm or monitor stand I suppose).
Yep, out of price range :(
Only just realised the price of this monitor. It is a possibility!
