** CHILL OUT ! **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We now list a range of waterchillers for extreme cooling performance.
Each chiller is brought to order and will arrive with you within a week.
A range of accessories to integrate these high end cooling solutions into your system will be listed soon.
Please Note: a water chiller should be used in place of a radiator.
To find out more about the capabilities of a Hailea cooler, check the excellent Bit-Tech review which gives a nice overview of the mid range HC-500A Model
Hailea Ultra Titan 150 Water Chiller (HC130=110Watt cooling capacity) @ £239.99 inc VAT
Ordered upon request: Delivery is typically around 1 week, but during busy periods it can take longer.
Award winning Watercooling Water Chillers from Hailea.
New cool design
More robust materials for even longer lifespan
Lowered noise emissions, Quieter than a standard refrigerator!
Suitable for continuous operation
This waterchiller basically replaces the radiator as the coolant is chilled to the desired temperature by this unit. Temperatures down to 4°C are possible, please note that at low temperatures (high temperature difference) condensate may accumulate. Suitable insulation accessories are also available in our shop. Alternatively the coolant temperature can be set to just below room temperature to avoid this problem. Thanks to the low temperatures incredible overclocking potential is available! This system is also great for no-noise applications as the chiller can be located in another room.
We recommend integration of the chiller into the cooling loop in combination with a radiator. This allows use of the chiller when required (overclocking, Benchmarks, summer etc..) and use of the radiator during normal operation.
To estimate the required cooling performance here some non-binding estimates. The exact thermal emissions can be requested from the manufacturer of the hardware.
CPU: 80W (standard) to 150W (overclocked)
GPU: 20W (small cards) to 150W (current models such as 8800)
MB: 10 to 20W per component
The added values of your system must not exceed the given cooling capability of the chiller.
• HC-130A
• 1/15 Horsepower
• Cooling Capacity 110W
• Recommended coolant flow - 200-1000 l/h
• Weight - 9,2kg
• Cooling agent - R134A
• Dimensions (LxWxH) - 338x218x325mm
• Heat exchanger material - Titanium
• Temperature adjustments - Digital read-out (precision 0,1°C)
• Temperature setting in 1°C steps
• Contents - 1 x Chiller
• 2 x 3/8" fittings
Note for first-time users:
If you should have problems with your chiller please contact us before returning the chiller to us. In most cases there is no actual problem with the chiller, but the functionality of the unit is not fully understood by the user yet. Please note the following: The compressor unit automatically switches itself on and off, if the temperature sensor is manipulated your warranty is void, the noise level or an allegedly not sufficient cooling performance are no reason for a reclamation. The chiller can only function properly if the cooling loop is equipped with a sufficiently powerful pump. If these facts are considered most reclamations can be avoided and you will greatly enjoy this product!
Note for aquarium-use:
The cooling performance is affected by the aquarium-lamp, the reduced pump power due to filters and the thermal waste of the pump. We therefore recommend to order the chiller at least on the power-lever higher than theoretically calculated.
Only £239.99 inc VAT.
ORDER NOW
Hailea Ultra Titan 200 Water Chiller (HC150=165Watt cooling capacity) @ £261.98 inc VAT
New cool design
• HC-150A
• 1/10 Horsepower
• Cooling Capacity 165W
• Recommended coolant flow - 250-1200 l/h
• Weight - 15kg
• Dimensions (LxWxH) - 420x248x365mm
• 2 x 1/2" fittings
Only £261.98 inc VAT.
ORDER NOW
Hailea Ultra Titan 300 Water Chiller (HC250=265Watt cooling capacity) @ £287.58 inc VAT
New cool design
• HC-250A
• 1/6 Horsepower
• Cooling Capacity 265W
• Recommended coolant flow - 600-2200 l/h
• Weight - 18kg
• Dimensions (LxWxH) - 448x330x440mm
• 4 x 1" fittings (2 straight, 2 right angled)
Only £287.58 inc VAT.
ORDER NOW
Hailea Ultra Titan 500 Water Chiller (HC300=395Watt cooling capacity) @ £313.99 inc VAT
New cool design
• HC-300A
• 1/4 Horsepower
• Cooling Capacity 390W
• Recommended coolant flow - 500-2500 l/h
• Weight - 18.5kg
Only £313.99 inc VAT.
ORDER NOW
Hailea Ultra Titan 1500 Water Chiller (HC500=790Watt cooling capacity) @ £436.98 inc VAT
New cool design
• HC-500A
• 1/2 Horsepower
• Cooling Capacity 790W
• Recommended coolant flow - 1200-3000 l/h
• Weight - 22kg
• Dimensions (LxWxH) - 475x360x490mm
Only £436.98 inc VAT.
ORDER NOW
Hailea Ultra Titan 2000 Water Chiller (HC1000=1650W cooling capacity) @ £644.99 inc VAT
New cool design
• HC-1000A
• 1 Horsepower
• Cooling Capacity 1650W (suitable for extreme OC and cooling)
• Recommended coolant flow - 2000-4000 l/h
• Weight - 32kg
• Dimensions (LxWxH) - 400x500x440mm
Only £644.99 inc VAT.
ORDER NOW
glad you included this! :p
I remember the Asetek Vapochill for the extreme overclockers, just as big, heavy and over the top;)
Hey I had one of those! Was great clocking my Thunderbird beyond 2Ghz and being 3D Mark World Champion for all of circa 24hrs. :D
If I win the lottery I'm getting one of these, and running an extra loop through a custom beer fridge :D
you need to use a dew point calculator to ensure that doesn't happen.
alternatively you can use Armaflex which covers the tubing if you want to go mental and have it at max power all the time.
we are listing this soon :)
