Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Spec in sig, maxed out on ultra at 1680 x 1050, felt quite good, enjoyed the game much more when I was in the underground action.
Minimum FPS 45, max around 115. Average was around 60-80.
HAd a few games now, quite good, i like the flashing of scopes though need to be a bit careful as friendlys also flash when aiming at you. There is some gfx flickering with me at the moment which is a bit off putting and the sounds dont seems as meaty as they were in BC2
[email protected]
6950@stock
8gb RAM
1900x1080.
Pretty much everything on Ultra, wasn't monitoring fps but it was very smooth indeed. I noticed the odd glitch but i think it was unrelated. Didn't notice any slowdowns at all. Biggest problem i had was vsync not working as i was getting tearing.
loving the gameplay, hating the huge spikes of lag every server seems to be throwing at me...sprinting can become like a slideshow in terms of movement
Anyone have issues going full screen? ALT + Enter and the option in video settings isn't working.
I'm also getting a freeze and sound loop after every 10-15 mins of play, which means I need to reset my machine.
Had less problems with the Alpha than this FFS!!
Works fine for me, 80+ FPS, no crashes. Only problem is sometimes I can't get into matches but that's a Beta thing I'm sure.
I never played Alpha. My thoughts are: Don't like the map, love the gameplay though.
It seems way more buggy than the Alpha, a lot of white flicker in game...getting a decent framrate on medium but it gets way to choppy if I up the settings, looks like the dice guy who said 580 SLi for ultra was telling the truth. :0
For those who have played it, can we have your system specs, and the resolution/gpu settings you need to get smooth play?
Q6700 O/C to 3GHZ
GTX 460
4GB Ram
According to fraps with everything on high I averaged 50 FPS and game play was smooth.
I did have problems binding to mouse buttons and still can't figure that one out.
I have no control over my character at all, it's like watching someone else stare at the floor, spin round, and then stare at the sky :(
Decided to run it with the following settings.
50-65 fps, stock (630mhz) sli gtx 470's
Not sure if this has been asked before but when this goes into public beta will i have to sign up for a beta key at some website or will it just be a matter of opening origin and it will be there for all to download?
Anyone getting the "import friends from Origin to work" It will only show up 2 for me.
Not that it really matters for the beta, i suppose it will be sorted for the final release
Status
