Did you do any tests on packet loss? What type of cable?
IME normal Cat5 will suffer over 100M.
have 200meter of cat6 from my mothers house to the shed at the bottom of the garden...
Good grief, that's the length of 2 football pitches.
I'd like to see a Google map of her back garden and I wouldn't like to cut the grass.
easiest solution is a 4 core fibre (2 spare) and use media convertors at each end to convert back to 100baseTX.
No point doing cat5/6 as the fibre is pretty similar in cost, your main cost is digging the trench.
Regarding the cat5 distance, i regularly order cross connects in data centres and none will install them if they are anymore than about 90m, allowing for a few metres at either end for internal patching.
