28 Sep 2011 at 09:47 #1 TheBrooder TheBrooder Soldato Joined 8 Jan 2007 Posts 3,319 Location Cognac, France Should I have the fan blowing through the cooler, or sucking the heat out towards the rear fan? (heatsink is vertical)
28 Sep 2011 at 09:58 #2 LtMatt LtMatt Caporegime Joined 12 Jul 2007 Posts 44,479 Location United Kingdom Which model do you have? If you only have 1 fan make sure its pushing air through.
28 Sep 2011 at 10:02 #3 TheBrooder TheBrooder Soldato OP Joined 8 Jan 2007 Posts 3,319 Location Cognac, France ok - there's only 1 fan and it's an older model (can't check it atm) I'll buy another fan if it's worth it
28 Sep 2011 at 10:08 #4 LtMatt LtMatt Caporegime Joined 12 Jul 2007 Posts 44,479 Location United Kingdom TheBrooder said: ok - there's only 1 fan and it's an older model (can't check it atm) I'll buy another fan if it's worth it Click to expand... I dont suppose its the Noctua NH U12P SE2 by any chance is it? I know they released that ages ago with one fan initially. Adding a second fan should lower temps another 2-5c. So it helps.
28 Sep 2011 at 10:17 #5 TheBrooder TheBrooder Soldato OP Joined 8 Jan 2007 Posts 3,319 Location Cognac, France Yeh, I think that's the one. Thanks for the help!
28 Sep 2011 at 10:31 #6 LtMatt LtMatt Caporegime Joined 12 Jul 2007 Posts 44,479 Location United Kingdom TheBrooder said: Yeh, I think that's the one. Thanks for the help! Click to expand... What system do you have? And what temps are you getting with that cooler? I started a thread just belows yours re that same cooler.
