*** League of Legends ***
Having Mumble login issues again, it won't accept the correct password.
Would me logging in from my gf's laptop and now from my own machine cause an issue?
Quite possibly. I'll message Tals for you :)
Edit: Just spoken to him, it's because you're using the same username on different machines. He's removed you for now so you can login but will need authenticating. Then you'll need to login at a later date on your other computer with a different username and get that authenticated. Hope this helps :)
Not true now with normal draft - as rogue blade so eloquently put it, people get far to into their stats and when it doesn't go right they rage because their stats are everything :)
Not true, and if people rage at you in ranked, behind the bluster there is a good chance you are doing something wrong. The rage is not about the stats, its about noobs playing outside of the meta and screwing things up :p
Jesus 4 losses in a row today. Either I'm total **** with Vayne or matchmaking hates me (2 leavers and an afker).
FRUSTRATION AHHHH!!!!
Been getting frustrated myself. Only L27 so not ranked but the Dominion release must be bringing in new players because I've been stuck with a few who were just awful. Feeding, walking right into ambushes as soon as an enemy champ showed on the minimap... frustrating stuff. Thankfully I'm now playing with at least 2 friends on a normal night so hopefully if that reaches 5 I'll at least have some people who know (barring messups) how to play.
Yes, it definitely would. Mumble stores a certificate based on your PC so you would be conflicting with it's file structure if you tried to log in from 2 different machines with the same username, without transferring your certificate of course, and would encounter the same problems as if I had tried to log in under the registered username Kr00t0n. Just use 2 different names for both machines and you'll be fine :D
You make a bad assumption that everyone is like you and at a similar or greater age than you :) Unfortunately with the Internet sanity cannot be guaranteed.
Unless you are a very good carry - only seen one amazing carry in my time playing and his ELO was surprisingly 1800 :) Then you're going to find you bounce around on the stats as its a team game being treated as individual in the stats.
Would far prefer they start to look at team stats in premade which they seem to have intimated in the last press release.
You can use the same cert (username) on two machines, you just can't log in to them at the same time. Export the cert on the first machine and import it on to the second.
I am having allot of success with soraka in dominion, its quite amusing. Take promote and garrison, max heal and starfall first, CDR, sit on towers, and when they dive you 2 v1 pop garrison, heal to get the +insane armor for 5 seconds, mash starfall, run around the tower dodging melee attacks. Can be really funny surviving what they think will be an easy kill.
Thanks for the mate, I think that is still one of my key problems with LoL is my want to jump in and fight, it's exciting, it's fun but the main thing is I don't want to see my team die while I just chill out and hang back but you're right I need to do that. I've started to with Fiddlesticks a lot more now and have noticed a much improved play style with him, I just think I need to adapt this play style with others; been a hard transition from Tanky DPS solo top to slightly squishier junglers.
You can poke with your q, and attack if they run into your team but if you jump slap bang into the middle of their team as soon as you are in range you are just giving them a free kill... basically the thing to learn is that as great as his ult is it is never to be used as an initiation in team fights as the 3 seconds it takes for the rest of your team to catch up with you is plenty of time for them to kill you and regroup for the rest of your team.
This is why i build him aggressively most of the time.... if you get focused you will die regardless so may as well not bother, rely on a banshee's and your own w to keep you alive, if you take more than 2 nukes then its time to run away
Thanks mate, I learnt my lesson last night, I paniced when they CVed my blue so during my life steal on blue I potted at the start.... 10 seconds later I died... You could hear in Dei's voice as if to say wtf.
I think I had my worst game ever as a jungler last night, although me Dei and Nes nearly did Baron super under farmed and at about level 9 :D
