Setting up as a business
My accountants are whiter than white and there is no way in hell they let me include any food unless I'm travelling oversees
yea sorry, ignore me, i didn't post what i was trying to say.
food cost incurred outside of the home as a result of undertaking business activities (including domestic UK) = yes
food at home = no; but what you can do is set a reasonable overhead based on your charge-out rates and build costs like this into it, especially if it benefits you financially even though you won’t officially be charging for it. i.e. if you were setting you overhead at 1.15 and you could set it at 1.2 then you would (still probably doesn’t make sense but hey)
food cost incurred outside of the home as a result of undertaking business activities - yes
food at home = no but what you can do is set a reasonable overhead based on your charge-out rates and build costs like this into it if it benefits you financially even though you won’t officially be charging for it. i.e. if you were setting you overhead at 1.15 and you could set it at 1.2 then you would (still probably doesn’t make sense but hey)
I inherently charge my clients for my food and my mortgage and my holidays etc!;) I'm not a contractor I have a small specialist economics firm
it is worth noting, that the items you can legitimately expense and importantly, how you account for these will also be dependent on what your company does. a good accountant will be able to maximise these intricacies for your financial benefit.
I know I have a decent accountant who understand my business well (big name not that that is everything), they ought to be decent anyway they're expensive enough!
my accountants don't like me including dining say in London, even taking colleagues out
that is fair enough then,
as a small business or sole trader, some claims may be a bit too transparent, but i am surprised you can’t claim for entertaining clients within reason. i could appreciate it being more complicated if your business would not require this type of hospitality in conducting its normal activities.
I think If you can prove it led to more work then its ok. Although surely it could just be eaten up as advertising
The problem is it can be seen as "Entertaining" which is NOT a business expense
Just get your own accountant. It'll be easier than sifting through a billion posts, and you'll have someone to blame at the end of the day.
I've always thought it's a bit conservative but TBH it doesn't happen very often at all and most of my clients are abroad so it's a non-issue when I see them anyway. I also have reimbursable expenses for food in my contracts (whenever I can get away with it!) so eat well while travelling for work!
My main company is an LLP
if you can demonstrate that it is hospitality (you wouldn't use the term entertainment) and forms part of business development then you can justify it.
this may require you to have a very clearly defined business development, marketing and company expense policy which works both ways as it; enables you to undertake such activities but also sets out a prescriptive approach which of course limits some good old ad-hoc pub time with your colleagues. for example you could pre allocate £2k in your annual budgets and business plan for hospitality and business development, it would be poor performance not to meet your own kPIs
sounds very credible way to approach it, thanks.
nice, fancy doing my accounts?
