ati 3d?
26 Aug 2011
Cork, Ireland
Has anyone used ATI equivalent of Nvidia's 3D, I've seen article on it before.
The list of compatible monitors isnt very many, even though its not on their list I imagine it should work on LG W2363D 23" TRUE 120Hz 3D Widescreen LCD Monitor
thoughts, views , opinions please....
I've ordered 2 sapphire 6950's which will be running in crossfire
If you want the best option for 3D then send your HD 6950's back and get Nvidia card(s).
+1
Nvidia make the 3D drivers themselves (AMD rely on middleware companies for the most part) and can make use of inexpensive dual-DVI 120Hz monitors (while AMD relies on HDMI 1.4 or Displayport 120Hz monitors).
If you plan to game a lot in 3D and your budget is modest, then I would also suggest swapping over for an Nvidia card and going for the LG 120Hz monitor you mention in the OP (it's a nice bit of kit at a low price) and the Nvidia 3D vision kit. Something like this GTX 570 would be a good option for playing modern games in 3D @ 1920x1080.
