I am looking for a suitable PSU for this system:
Currently using:
AMD Phenom II x4 965
4GB DDR3 Memory
3x SATA HDD's
I am also on the market for a new GPU and will most likely be getting the gigabyte GTX 560ti here:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-074-GI
I use two of these in my own system and I am extremely happy with the performance. If there are any great offers on the 6950 I should consider please let me know, but I am very happy with the tried and tested performance of the gigabyte 560ti
The PC will be used for games like Battlefield 3 @ 1920x1080 and hopefully will be capable of ~30fps with most of the settings maxed
In addition to a PSU and GPU I am looking for a 20M Ethernet and 2M HDMI cable. The selection is quite overwhelming. I don't understand how more expensive cables will perform any better, do you have any suggestions?
For reference:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-049-OK 1.8M, HDMI @ 5.99
I like how it says "3D ready" but I am sure that is just a fancy way of saying it's "v1.4". And 1.4 HDMI cables can be found cheaper. The same can be said for ethernet cables. I don't want to buy cheap unreliable cables but at the same time I don't want to be paying extra for nothing, help me out please =)
Thanks for the suggestions
Currently using:
4GB DDR3 Memory
3x SATA HDD's
For reference:
