BF3 Beta FPS thread
Yep, got the preview 11.10 drivers installed.
I mean, the table posted in the first page suggests my fps is what is right for my setup:
So I dunno how people are getting 60+ fps on similar/same setups.
GPU: Geforce GT 540M 2gb
CPU: i7 2617m
Resolution: 1366x768
Average FPS: 30fps (vsync on)
Driver version: 285.38 beta
Running medium settings with 4x AA perfectly playable on my Alienware M11x R3
very happy this can run it! fraps showing a solid 30fps sometimes dropping to 28 or 26 if things get very busy but feels smooth.
Cant wait to try it tonight on my home rig see if it will run eyefinity.
At 2560x1440 iam getting average of 55fps with all setting high apart fron texures which are on ultra and no AA..
Thats with 470 sli Which I am about to put a 3rd in see if that makes a diffrence :o
What would you say is the best tool for getting FPS?
Using fraps on my Ati 6990 auto settings getting any thing up to 200Fps stable around 150 mark,
Change the settings to ultra and looking about 95 or so.
I have the exact same setup and resolution (6950 is unlocked, but clocked at 900/1375 though) 2500k is overclocked to 4.6GHz, but I only get around 30-40fps on Ultra with Vsync off.
Mine defaulted to High, which was weird since yours defaults to Ultra.
To be honest some people talk utter crap about the performance their getting.
I'm beginning to think that too.
Looking on Neogaf, people with 2x6950's (unlocked+overclocked) are getting 80-100fps, with 2500k's. Some others with 580's are also getting near to 60fps, but not constant. So I'm thinking some people either switched their settings to Ultra, but forgot to close and restart the game as the settings don't change unless you do that or the round ends, or they are telling porkies.
I thort dice said ultra was disabled for beta, even tho the option is visible. IM getting fairly high fps
around 45-70 average on a single 580 @ 1080p
yeah, I don't think there is a difference between High (medium?) and ultra, looking at the above benches 580 sli will struggle to keep ultra above 60fps. :eek:
....of course, we may see big improvements for multi GPU systems with driver updates.
well i can report the beta scales very well with tri-sli and is a lot smoother now at 2560x1440 gettin 60+ fps in out door areas and 90fps indoor
