2500k Temps
Hi I have the same setup as you but I am at 4.6ghz, I used arctic cooling mx4 paste though and it is on a Gigabyte z68 board. My temps at idle are 28-30C after 4 hours of prime95 were 67 - 71C so I think your temps under load are OK
Will
It does seem a little toasty but well within specs for a i5 2500k. I wouldnt worry too much unless you start hitting 80's, then id start to look at reseating the cooler and checking the TIM is applied correctly ect.
Hottest core hits 76 during prime in this hot weather, never sees anywhere close to that in gaming or adobe suite so Im not too bothered.4.5@ 1.36v 2600k
