Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
What a stunningly beautiful game at ultra settings!
Has anyone else come across the "Blue Screen of blurry effects" bug yet?
Like the blue effect on the screen when you're watching someone and waiting to be dispatched remains on the screen when you spawn. Which makes it very hard to see/kill anything
You just hit Escape and it fixes that.
this is a bug with the option menu.
if you press esc when you watch kill cam it wont load the menu but gives you the blue effect. pressing iut again will open the menu getting rid of the blue pressing again to close then brings your colours back.
Do FPS go down or up on Caspain map compaired with Metro? Which is the more stressful on hardware
ON my 5770 I have most things on high and get ~30fps on metro and drops to 25 on caspian will need to tweak settings if i play that map again but metro is supprisingly fluid at 30fps even in lots of smoke only drops to 27ish will probably drop a few settings down.
my 1055T isnt taxed at all, all cores are used at about 60%
let us know what bugs you have and i will posting detailed reports to DICE/EA via there message board. (as im a fully certfied Software Tester i know how the developers mind works)
every time i try to get into a server it gets to initializing then just disappears,cant get into any game,also it says hit alt+enter and go to full screen but it wont do it,anyone else had this cheers
http://battlelog.battlefield.com/bf3/devblog/view/2826551893985321517/
We have distributed a server side update with the following changes:
- Terrain destruction disabled, because it causes problems with people crawling around under the map. We have a proper fix for this in the retail game, but chose to simply disable it for the OB
- Preround is fully activated: 8 players required to transition from preround to in-game; when 8 players are reached, the start-timer is set to 10 seconds
- Fixes for the most common game server crashes reported over the past 48 hours
- Fixes for end-of-round progress reporting to Battlelog (so players will see their progress more detailed on Battlelog)
The Server Providers have been instructed to deploy before Fri Sep 30th, 0800 UTC (when it impacts players the least).
Downtime should be minimal.
Going to get a lot of whine over that lack of destruction.
Lol i'm requesting an EA ID change for the 3rd time. I can see this going wrong at some point. But they'll hopefully learn not to be so retarded with the soldier name in the next series of games.
I saw a couple in high 30s and low 40s last night. However, could've been playing non-stop and picking off noobs or hacking, who knows!
Status
