ATI 6950 broken fanblade
20 Sep 2011
I had bought all my parts from overclockers for my pc build. Being the moron I am, I turned the pc on with a small wire inside my graphics card fan, instead of the wire breaking or the fan stopping a fanblade broke. Now my pc makes an incredibly large amount of noise and I'd like to know whether there are replacement fans or somewhere that will replace the fan for me? I've only had the graphics card for around 3 weeks now.
Avoid posting about it on ocuk forums and then say it was damaged out of box! Is it still within 7 days for DSR?
The new cooler would come with a new fan as a package and therefore replace the broken fan currently installed.
Noise-wise, I can only suggest maybe play games with ear phones, or as they suggest with my car and VVT rattle - turn the music up :p
I can't link directly to it as a competitor sells it, however search for 'Arctic Cooling Accelero Twin Turbo' and that is the sort of thing you're after - generally quieter than the stock fan and from my experience perform better as well (back in the ATi 9800pro days)
errr I tried that cooler and although it would fit to the 6950, it would not be enough to handle the heat generated from a 6950.
