MSI 460 owners in here
Caporegime
24 Dec 2005
Autonomy
What stable clocks are you getting?
What should I expect?
You can get the core clock up to 850mhz plus. Around 860/870mhz is the most you can get from this version of the GTX460! And upto 2000mhz on the shader clock!
Each 460 is different and the MSI version is decent at overclocking and has a decent cooler on it.
Use MSI Afterburner to overclock it and then use Unigine Heaven to benchmark it. Look out for artefacts (blocks or white or black errors in the rendering of the graphics, extra shadows that shouldn't be there). If you get these, tone it down a bit and watch them TEMPS. Anything above 80C then stop the OC!
Read this thread I helped another GTX460 owner with: http://forums.overclockers.co.uk/showthread.php?t=18321379
Hope this helps!
well I have a cyclone model watercooled @ 900 - core 1800 - shaders 2000 - memory @ stock volts if that helps :)
