- 7 Jan 2007
- Sussex, UK
i got 12gb 3x4GB G.skill Triple channel ram have i done well?http://www.gskill.com/products.php?index=265
Yes, but gskill are crap
Hitboxes are massive, the amount of time I have just gone behind a wall to take cover then suddenly die is annoying.
Nades are weak and they don't even roll.
Is that the app you need to install as part of your web browser so as to see the game servers?
Be advised, i got shot through rocks this morning, was prone and rather confused.
No idea, its when i go to start the game from my origin screen, a window opens and mentions battlelog and aload of mumbo jumbo and app not found.
Check to see if it's installed in Programs, if so uninstall it. If not, what browser you using?
Yep it was installed but i unistalled it, using IE9.
Anybody else getting their virus software detecting malware with Origin when downloading BF3? I got it twice using Avira anti virus.
Michael
Use a different browser and reinstall the app. Also make sure you're not using Avast!
