I can't say whether the following results are accurate but they come from a respected benchmarking tool and were just released today, namely Passmark7 so chances are these are fairly close to accurate, unless anyone here knows better.
OK so the FX-8150, AMD's top of the line desktop CPU scores, compared to Intel and AMD's older offerings.
CPU overall score
Intel Core i7 995X @ 3.60GHz 10945
Intel Core i7-2600 @ 3.40GHz 8941
AMD FX-8150 8681
AMD X6 1090T overclocked 7290
AMD X6 1100T 6314
Just looking at this is depressing for me. I was really hoping the 8150 would be significantly faster than the 1100T
I still need to see more benchmarks, especially cinebench which relates perfectly to what I use the cpu's for, Cinema 4D for 3D work but also that moving to an expensive 990FX board, which is something you have to do if you want to be able to later take advantage of even faster CPU's from AMD and make use of everything the CPU's have to offer, well it just doesn't look that attractive to me anymore.
A cheap AMD board that can run a 1090T is still a beast compared what Intel offers at the same price point and holds its head up even against Intels more popular monsters. For instance check the following multithreaded CPU results in Cinebench as published on their site.
Intel Core i7 980 @ 3.79Ghz £stupid money 12.19
Intel Core 17 2600K @ 3.4Ghz £293 8.12
AMD X6 1090T @ 4.23Ghz (overclocked) £140 7.30
Yes its unfair to compare standard with overclocked but I don't care what's fair. I care about getting the best value for money in my next CPU purchase. So while I know I can overclock the 2600K brilliantly, it's still £293 and the motherboards are still expensive, and its lifespan is still limited with motherboard types changing so quickly on the Intel side.
So far I'm concluding that the best value for money for 3D rendering is a 1090T on a decent but cheap board with a third party air cooler so it can be overclocked reliably. My dreams of a bulldozer chip that's twice as fast as the 1100T seem to be all but dashed and without at least doubling in speed, there's really no point in upgrading IMO. I should also add that for gaming this isn't the same. My needs are for as many cores as I can get with as much ghz as I can get. Games benefit more from quadcore chips that are rated higher than the AMD X6 cores so even AMD's own quadcore chip is better for gaming and intel wipe the floor on clock speed for quad cpu's.
I'm currently on one of the old AMD Quad 620's overclocked which gets 3.60 in cinebench so that 1090 gets me my doubling in performance and I dont even need to change my motherboard.
Hope this is of some use to any 3d heads looking for bulldozer info and I actually hope the passmark scores are way off and the 8150 ends up being better than these scores suggest. Have to wait a few weeks yet I guess.I'm also dying to see if the 1090T drops in price. I can see its already dropping a bit on some sites, including this one.
CPU overall score
AMD FX-8150 8681
AMD X6 1100T 6314
