- 7 Jul 2009
- Newcastle/Aberdeen
Well i've been using a Casio fx-83ES for a while now, and it's been a bit iffy for a while (screen flickering) it just completely gave up in the middle of calculating empirical formulae on Friday (not a build quality issue i don't think, just to do with the way i was treating it - and the whole 'leaving it under the sofa for two years' thing). While i've found another one to tide me through until i make a decision, i'm wondering if this would be a good time to get a completely new one. So i started googling. Then i got confused.
So i need something that i can use for (at least) A(S?) Level Maths, Physics, Chemistry and Biology, and by 'use' i kind of mean 'would allow me to cheat at as much as possible, while at the same time not risking not being allowed in an exam'. Budget i'm not really sure, i have enough money left over from my birthday to get a high end graphing calculator (which would be the epitome of nerdiness), but to be honest i'm not sure what i'd actually use it for. I've heard good things about the fx-991ES Plus, but then i started to wonder if Casio actually is the be all and end all of calculators. That said, when i look at Sharp or Texas Instruments they always look too different from what i'm used to, be it either with key placements or screen size/layout. The only functions i would need (really want?) that might not be on all of them would be a fractions button, a minus button, S>D for converting answers given in fractions to decimals and vice versa, as well as all the usual stuff (log, lin, sin(^-1), cos(^-1), tan (^-1), π etc.). So... any suggestions? Thanks
Of course, having a better calculator is pointless if you don't know how to use it, so are there any decent guides or whatever that could help with that (other than the instructions of course
)? I know there's a lot on my current calculator that i've never touched, but i'm not sure if it could have helped me at any point.
tl;dr - i'm a nerd, spec me a calculator. Cheers
