- 24 Dec 2007
Hi guys,
As the title says, I'm gonna be asking about CPU Coolers, Power Supplies and additional/replacement fans here
First though I'll give you a rundown on my rig:
Case: CM ATCS 840
Motherboard: Gigabyte EX58-UD5
Memory: 6GB (cant remember make or model but not pertinent here anyway
CPU: i7 920
Cooler: Fenrir v1
GPU: 1GB 5870
PSU: 1000W Non-Modular (Corsair I think)
HDDs: Crucial M4 64GB SSD, 250GB OCz Apex SSD, 2TB Samsung f4
Soundcard: Xonar DG
Ok, so CPU Cooler first. Lately I've been hearing this incredibly annoying whining that starts anytime while doing anything and which I can hear in my headphones. I'm pretty sure it's from my Fenrir which is probably due for an upgrade anyway, so I'm going to do so.
I really liked the idea of an all in one easy to use watercooling system for it so I've been looking at a Corsair H80, but reading around I hear that the Antec Kuhler H20 http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-AN is the better option.
1. Which of these would I be better of going for? Or would something else entirely be different?
I like the idea of such a loop because of the amount of space it saves around the CPU area, leaving me a lot more room to manouvre and sort out wires etc, so ideally I'd rather not go for another air cooler unless they are significantly better performance wise (I could live with 5 degrees hotter or so on the loop just for looks and size alone).
2. I have read the Kuhler has paste on it already also, is that worth using or applying high quality paste myself? Which paste and TIM cleaner are the best (price/performance if that's a better indication) for such a cooler?
Next, we come to my power supply. While it's not giving me any problems, and I probably won't be replacing it at the same time as my CPU cooler I figured I would ask this hear anyway as it has been on my mind.
3. I really want a modular power supply for ease of use and upgrading (mine is a pain for HDDs and stuff), and I'm pretty sure 1000W is far too much for what I use so what would people recommend for a Modular power supply in an ATCS 840? Bear in mind that I plan on *possibly* adding a more modern ATi card in the future and running the 5870 as a second card, so it would need to incorporate that and any additional fans in the case (2 I think can be added)
4. Now, about fans. In an ATCS 840 there is room for 2 extra fans attached to the HDD bay. Obviously with two large fans exhausting out of the top of the case and the cooler exhausting out the back, I feel like there is a difference there. Is it worth it? Also, which fans would be best suited for such a job?
5. Also, including anything from the previous questions, is it worth replacing any fans elsewhere (Such as the Kuhler/H80, stock fans on 840 etc)?
6. Additionally, I need 2 SSD support brackets for my drives (They're sort of hanging there at the minute
), which would you recommend as I'm completely clueless about sizes and build quality in such an area.
Thanks for reading, and I appreciate you taking the time to reply if you do
Case: CM ATCS 840
CPU: i7 920
Cooler: Fenrir v1
GPU: 1GB 5870
Soundcard: Xonar DG
