How to increase the FOV in BF3 from the locked 70 to 90 :)
Status
Not open for further replies.
17 Mar 2009
Nottingham
Evening chaps.... Just found this so i though you might want to get in on the FOV goodness.
Currently the BETA FOV is locked at 70 degrees but you can force it to 90 degrees if you do the below:
NOTE THIS WILL HIT YOUR FPS HARD!!
Find and open PROF_SAVE_body with NOTEPAD
About the 6th row down find FieldOfView 70.000000 and change it to 90.000000
Enjoy a more awesome FOV :)
UPdated as opening and svaing in wordpad corrupted the file and caused the game not to load, do the above in notepad and its fine
I tried looking through the main thread before, went through about 10 pages before giving up, the main page doesn't even have it.
Threads should get locked once a certain post count is reached, it keeps the info up to date when a new thread is made.
Might be a coincidence but beta won't launch for me after trying this. Even changed it back and it still won't. Says initializing in battlelog then nothing
Did this and now my game won't launch, sadly. I will try fixing this :/
I just went and renamed the file to something else and the game launched now.
thats what done it, no wonder my game wont launch stuck on itializing, how do u fix this guys............................feel like punching OP in the face
can u give us an update on how u fixed it if u manage it.
Might need the original unaltered file (rather than just changing it back in the file) if the game has any kinda file integrity check to prevent cheating.
can somebody upload unedited
prof save body
prof save body header
meta
C:\Users\zzzzzz\Documents\Battlefield 3 Open Beta\settings in that folder
Use a decent text editor like Notepad++ whatever editor you have used has broken the file. Delete the broken file, launch the game, exit and edit it again with Notepad++.
It's because HybridX told everyone to use wordpad, which breaks the file
Status
