i bought a Compro E700 pcie dual tuner off the MM a while ago, and it was working brilliantly at home - good reception, good recording etc etc
i am using it on the default WMC player
i have come up to uni, connected it to the flat aerial (the same aerial feeds 300 flats) and every channel works flawlessly apart from the BBC channels
bbc1, bbc2, bbc3, bbc4, bbc news 24, etc etc they all just keep breaking up
WMC can download the guide, so i can see what is meant to be playing, but it just keeps breaking up
i have tried re scanning numerous times, wiggling the aerial in case of a loose connection, changing the postcode, and i went to reception to ask if there was a problem with the aerial and there is not - it must be my setup
