- 1 Oct 2011
- UK
Guided missiles for jets! Hope they put that Caspian back up before the end of the beta, way better than metro.
This article goes on about the difference between high and ultra...
http://www.geforce.com/Optimize/Guides/battlefield-3-beta-performance-guide
http://forums.electronicarts.co.uk/...sible-battlelog-no-squad-management-game.html
so you can join as a a team by creating a party in battlelog if the server has enough empty slots and does not have team balancing enabled and once ingame you have the option to leave squad or rejoin the same squad and nothing else
Nice article Wes, though the 570GTX on my machine allows me to run Ultra with 45+ FPS costant. i guess the CPU Hyperthreading helps maybe?![]()
GeForce GTX 580
For those who are lucky enough to own a GeForce GTX 580, expect a near-perfect experience. We're talking about 1080p at fully maxed out settings (Ultra). You have to hand it over to DICE for their lighting engine; at Ultra quality, the radiosity lighting, soft shadows, and ambient occlusion come together and play off each other to produce scenes so rich and nuanced that they look like they had been art directed. At this quality, the game plays like a trailer.
i pre ordered and got metro, but how do i get Caspian?
Anybody who keeps being kicked disable UPnP in your router, has worked flawlessly for me since i did this and i was being kicked nearly every round
I just did this, now my xbox lives nat is strict....... and now i cant find my thomson router on my pc, any ideas?
from a quick google it seems you have to turn uPnP back on or forward the ports for xbox
http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
Text you friend back sayingg 'you talk crap'
Im having bad feeling about DICE at the momentSeem to not be listening and doing things slightly wrong! Has no one told Dice 'Dont fix whats not broken;
I have turned upnp back on, should i turn it off again and forward the ports for xbox live?
