Wait... isn't delta T the relative difference in temperature? In this case, both being exactly 15K?
This is why I do coding in the morning and not the theory
Better thing to do is to go and make a cup of tea!
This is why I do coding in the morning and not the theoryI'll now plead that the heat lost via radiation will be stronger for the higher-temp cup as the heat loss is proportional to the absolute temperature (to the fourth power).
They will arrive at equilibrium at the same time. Heat transfer is dependant on temperature difference. Since the difference is the same, it does not matter if one temperature is greater and one lower, the heat transfer is the same.
This can be shown to not be true or at the very least there are some results that are challenging to explain. Seriously, take my earlier suggestion and read up on the Mpemba Effect.
I don't really see how the fact it was being discussed in the pub makes any difference either. 2 + 2 doesn't equal 5 just because I'm in the pub - I don't accept that the location of the discussion should result in a lack of precision. Given that it is fairly clear that there won't be a vast difference in times between the two changes in temperature it is safe to assume that you are going to need to look at the finer mechanics of the situation.
I would assume hot water would cool faster than cold water warming. As there are more processes for heat transfer in hot water. Such as steam.
Yes steam, steam is water vapour and the hotter something is the more evaporation you have, at 40 degrees you have far more than at 20 degrees. Although I suppose common terminology is condensed water vapour in the air.
So perhaps replace steam with evporation.
If you tell me that you'd get this involved were this question to come up amongst your friends at the pub, I'd dispute that you'd ever be sat in a pub with people you could call friends.
I need more information on said glasses of water:
1. What shape are they
2. what height
3. are they half-full or half empty?
4. Do either of the drinks belong to me?
I have a wonderful circle of friends thanksI'm sure the OP can confirm that I really would go into that level of detail and I am sure that over a few beers we have done exactly that. 5p says that this discussion was likely with a guy both of us know (and who occasionally posts on here as TrX).
Assuming perfect conditions, they'd be exactly the same shape - height, width, even thickness and the same material composition for both, as well as exactly the same volume of water. But if we're taking near-negligible factors into consideration, we'd need to know exactly what manufacturing process was used to apply a C.V. to the final rate based on likelihood of non-uniform density, manufacturing impurities impairing or aiding conductivity, contamination from storage conditions and where that dirty lab tech's been sticking his hands before setting up the experiment, he's never been the cleanest fellow and I happen to know he's been quite chatty with that Melissa from reception, you know, the one with the lazy eye who always smells like she's just come off a treadmill and who knows what that'll do to the scientific impartiality...
And no, neither of the drinks belongs to you. They belong to science.
Aah, you've caught mme by the short & curlies there - I've always understood steam to be a direct result of boiling water and thus wouldn't be applied to evaporated water vapour, but again it's a while since I diddled with the specifics. Then again, the process of evaporation is little different than localised boiling - best stick with evaporation, you don't want to go overheating my work-addled brain![]()
Steam is water vapour at a temperature in excess of 100 degrees C.
I understand what you are saying, and agree, if we were going to measure the difference at an accurate enough level, then yes, there would be a difference due to microphysics processes, of which things like evaporation and the Mpemba effect would fall under. I had considered the question in a perfect world physics exam scenario, where the water can be treated as a single entity with one variable parameter, temperature. I don't know by how much the evaporation would increase the time difference on both liquids reaching 25 degrees. Does anyone have an idea?
