- 31 Mar 2006
- Sydney Australia
i prefer man-onaise.
creamofsumyunguy?
Salad cream pwns mayo
No one in the history of the internet has ever been so wrong.
A decade of not knowing who you are, who your loved ones are and peeing and pooing in a chair in the corner of a nursing home. No thanks.![]()
Mayo is horrible.
But it looks like I'm in the minority so I will go and sit in the corner.
I'll send over a bottle of salad cream so you can drown your sorrows.
That's disgusting too
This is a subject I feel very strongly about. Particularly where tuna is involved.
Light mayo - NO!
Tuna mayo MUST be made with Hellmanns original full fat. This point is not open for discussion.
The tuna must be in sunflower oil. Tuna with either spring water or brine dilutes the mayo, and subsequently does not mix correctly and destroys the texture, as does adding cucumber (die!), or sweetcorn (DIE IN A FIRE!).
The following are the only appropriate additions to a tuna mayo sandwich (which incidentally should only be made with real, salted butter, never margarine):
- 3-5 twists of a grinder containing black or mixed peppercorns, white pepper is unacceptable, as is pre-ground "pepper powder".
- Grated Pilgrim's Choice or Cathedral City mature cheddar - this can be coupled with the pepper mentioned above.
- Encona Hot Pepper sauce. This should not be coupled with either the cheese or pepper mentioned above.
Where tuna mayo is served with baked potato, allowances can be made for both baked beans and other cheeses.
Heinz mayo is the preferred choice where chips, fries and potato wedges are concerned, however in all other circumstances, Hellmanns should be issued as standard.
77% fat in normal mayo. No thanks
WRONG. (in parts)
Tuna has to be in spring water or the texture is wrong and I am open to discussion on cucumber but sweetcorn you can go and burn for all I care.
Also cheese with tuna mayo!? ARE YOU MAD!?!?!?
