i agree intel processors are good, but AMD's processors are superrior to the equvilent intel.
Because your IMC can't cope.
AMD's IGP dominate Intels.
Their CPU performance leaves a lot to be desired though (At present).
Llano is a desktop chip ; FM1 (Also comes in a laptop variant) Trinity is touted FM2 and uses piledriver cores (If that's still the case?)
whats IMC ??
Yes, but Trinity is only 2 module / 4 core?
AMD haven't specified any 4 module / 8 core Fusion CPUs that can really go head to head with SB.
Integrated memory controller.
If it's not upto the task, then it can't handle higher frequency memory.
i want to buy the highest performance bulldozer coming out but i will need to start from scratch to make a computer good enough so i don't have to upgrade it for a couple of years.
any ideas on a decent graphics card?
Doesn't the Phenom II IMC on "officially" support 1333mhz and down, with 1600mhz considered an "overclock"?
it should be able to run it on lower MHz ...
mobo has even an option to tune in memory but it didnt help...
For what they are aimed at Fusion walks over SB. General use for Joe Bloggs does not need an i7 2600k and a HD6990
The individual cores or modules are a lot slower than SB for sure. But SB is very, very quick!
Except that I've not seen any desktop Llano builds in shops (Have a look at the purple shirt place etc), I've only seen 2 Llano laptops at purple shirts on site.
Didn't say Joe Bloggs could actually buy one did I?
Horrific shortages of good chips I read somewhere
I still want to hear about AMD's superior CPU's
The highest Zambezi will be the 8170, but that's not launching initially.
would the GTX 590 not be a better card than the 8170?
