** CRAZY WEEKEND MONITOR DEALS - MASSIVE DISCOUNTS (UPTO £100 SAVING) WEEKEND ONLY! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
This weekend is a great time for monitor buying as check out these great deals:-
Samsung S27A750D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £529.99 inc VAT
Samsung’s 750 and 950 series 3D desktop 3D monitors feature high refresh rate, incredibly thin bezel and stylish design. These monitors are able to analyze and render 2D content in real-time to 3D, supporting PC content, Blu-ray films and gaming consoles. The monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3D active shutter glasses.
Viewers will experience deep, rich colours and image clarity with Samsung’s new Ultra Clear Panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. The LED-backlit panel boasts 100% sRGB coverage to produce realistic colour reproduction.
Features:-
- 3D Active Glasses are included
- TRUE 120Hz
- 2D - 3D Conversion technology
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms (2D) / 2ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x DisplayPort
- Warranty: 3 Years On-Site
Only £529.99 inc VAT.
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Glass Monitor - Black @ £499.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
These monitors use a glass coating on the front which results in much sharper images quality, more vibrant colours and an overall better viewing experience. The downfalls of glass fronted panel is the monitor weighs a lot more and the manufacturing process can lead to dust particles been trapped between the panel and the glass which can sometimes be spotted when up very close to the screen and with certain solid coloured backgrounds.
Features:-
- Glass front panel for improved image quality
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- Kensignton Security Port
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
- 3yr RTB Warranty (UK customer only)
Was [£599.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Monitor - Black @ £499.99 inc VAT
Features:-
- 1 x DisplayPort
- 2 x HDMI
- 1 x RGB VGA
- 1 x L/R RCA Audio
- SPDIF Optical Out
ORDER NOW
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Glass Monitor - Black @ £379.99 inc VAT
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- 1000:1 / 1,000,000:1 (Dynamic)
- 2.5mm Audio out
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
- Only available to customers in the United Kingdom
Was [£439.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Monitor - Black @ £379.99 inc VAT
Features:-
- 2.5mm Audio out
ORDER NOW
Asus VE278Q 27" Widescreen LED Multimedia Monitor - Black @ £239.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. VE278Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. AI Light function enables the VE278Q automatically adjusting to lower brightness and make your eyes feel more comfortable in the dim environment. Furthermore, it helps save more 25% power consumption. Embedded digital HDMI and DisplayPort inputs, VE278Q enables the most advanced graphic cards/ computers connection. The DisplayPort interface also offers better support of multiple display streams, longer cable connection, and interoperability with other inputs, such as VGA, DVI and HDMI. Need to research on the Internet, but a championship game is about to start on TV? The VE278Q offers PIP(Picture in Picture) function(via hotkey) and has the capability to display images of two different signals at the same time. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 27.0"(68.6cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 4 Modes
- Picture-in-Picture
- Audio Features Stereo Speakers : 3W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 24~92 KHz(H)/ 50~85 Hz(V)
- Digital Signal Frequency : 24~92 KHz(H)/ 50~85 Hz(V)
- Power Consumption Power Consumption < 45 W
- Power Saving Mode < 2 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 643x445.6x220mm
- Box Dimension(WxHxD): 732x560x176mm
- Weight Net Weight (Esti.): 6.5 kg
- Gross Weight (Esti.): 9.8 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Asus VE276Q 27" Widescreen LCD Multimedia Monitor - Black @ £224.99 inc VAT
VE276Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Be captivated by stunning images with ASUS Smart Contrast Ratio (ASCR) technology that boosts the display´s contrast ratio to an astonishing 100,000:1. AI Light function enables the VE276Q automatically adjusting to lower brightness and make your eyes feel more comfortable in the dim environment. Furthermore, it helps save more 25% power consumption. Embedded digital HDMI and DisplayPort inputs, VE276Q enables the most advanced graphic cards/ computers connection. The DisplayPort interface also offers better support of multiple display streams, longer cable connection, and interoperability with other inputs, such as VGA, DVI and HDMI. Need to research on the Internet, but a championship game is about to start on TV? The VE276Q offers PIP(Picture in Picture) function(via hotkey) and has the capability to display images of two different signals at the same time. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Brightness(Max) : 300 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 100000:1
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Power Consumption Power Consumption < 70 W
- Power Saving Mode < 1 W
- Tilt : +20°~-5°
- Weight Net Weight (Esti.): 7.2 kg
- Gross Weight (Esti.): 10.5 kg
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, EK, J-MOSS, Taiwan Green Mark,RoHS, WEEE, WHQL
Was [£239.99] Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £199.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Contrast Ratio: 20,000,000:1
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
Was [£229.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
IIyama Prolite E2473HDS 24" Widescreen LED Monitor - Black @ £149.99 inc VAT
The ProLite E2473HDS LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr On-site Warranty
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black @ £149.99 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Contrast Ratio: 60000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
Was [£159.99] Inc. VAT
ORDER NOW
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £149.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- Pixel Pitch : 0.272mm
- SPLENDID Video Preset Modes : 5 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- AV Audio Input : HDMI 1.3
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 35 W
- Tilt : +20°~-5°
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Was [£169.99] Inc. VAT
ORDER NOW
Samsung S23A750D 23" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £379.99 inc VAT
Features:-
- TRUE 120Hz
- Screen Size: 23" Widescreen
Was [£399.99] Inc. VAT
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £199.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was [£219.99] Inc. VAT
ORDER NOW
These are truly exceptional deals, the lowest pricing in the UK by far on several of these models, these prices are valid only until 9am Monday 10th October, so grab yourself a bargain now. :)
Just wondering.
I was going to order one of the 27" Hazros, i know if i get standard next day i get free shipping which is about £11. Idealy i would like it to be saturday shipping, which is £17, can i just pay the extra £6 to have saturday shipping? Trying to order it now and it wants the full ammount =/
Not sure if it works like that or not.
Thanks!
There's a Samsung LS27A750DS/EN mentioned on Amazon,
but it's description is
Samsung LS27A750DS/EN 27 inch 3D LED TFT Monitor with 3D Glasses (MEGA DCR, 1920 x 1080, TV Tuner, 2ms, HDMI/Display Port, 300 cd/m2) - Black
Note the TV Tuner bit.
Are these two models the same? Both 2ms responce, but does this monitor include a TV Tuner?
There is two models, ours is without TV tuner, hence the much lower price.
That is just a typo. The model is the S27A750D, same as OcUK are selling - there is no TV tuner on this one. There is a 60Hz model with TV tuner and 3ms grey to grey response time called the T27A750. Note that the price is more expensive because Amazon themselves don't have stock, only a marketplace seller. OcUK is currently the only big-name retailer with any stock on the S27A750Ds at the moment. Even Samsung don't have any in their Euro QA labs at the moment. :p
Just wondering how much dust behind the screen is considered a "manufacturing defect". I ordered the glass WC from competitor and there was a finger tip size amount on dust bottom corner (small amounts in other areas, but that was the most significant). They refunded me in full. What about you guys?
this occured on an earlier batch of the monitors but has now be "solved" according to hazro
