Can You Beat
Possibly. :D
But lets not rain on my parade just yet. ;)
Unless you're using something like phase change cooling ,or you live in the Arctic, with the windows open, then 5 degrees can't possibly be correct.
It's physically impossible with air or water cooling to cool below the ambient temperature. The best air or water cooling will get you to a temperature a few degrees above ambient.
Theres goes my bombfire. :P
last night was about 7*C here, my set-up with 1055T overclocked and water cooled was idling at about 15*C or so, does that count? :confused:
Edit: and yeah like the person above said, 5*C isn't doable unless the ambient temperature is shockingly low, with air cooling probably like -5/10*C would get you that result, but since nowhere in the UK has been that temperature since winter then guessing its a dodgy temperature sensor or something!
All we ask for is a screenshot. :)
Bad luck.
