Signature pads - how do they work ? (banks, courier services...)
22 Dec 2010
Slovakia
Hello, I've heard that some courier services use signature pads for handwritten signatures instead of paper ? Is that true ? I was wondering about their safety: if you enter your signature in a digital form once that it's in system and due to its digital nature it can be copied easily. So what stops someone from taking advantage of it e.g. using copy of that signature in your name on the next delivery while actually never giving you the package ? (stealing it etc.)
Are there some differences in security when comparing signature pads used in banks vs. courier services ?
Since signature pads are common in banks - (which seem to be quite trustworthy institutions) the safety probably is there but still - can someone explain to me how is it possible that at some point in time the full unencrypted digital representation of your signature must be in the device and yet it is somehow assured that bank can not use the same signature (by copying the digital data in it) to sing another documents in your name without your knowledge ? Does the signature process require hash of the document being signed on input of the signature pad and then encrypts the hash together with your signature data ? Does each signature pad use device unique encryption keys that are "hardwired" into the device ? Or how else does it work ?
And what if attacker had physical access to the device - wouldn't it be possible for him to reverse engineer whatever the signature pad is doing (all the keys used for encryption etc.) and thus make it appear as if you have signed document which you have actually never even seen ? In other words could it be so that the crucial part of the security lies in the fact that signature pads are "black boxes" where you do not see what exactly is going inside ? (and that maybe they are specially designed to be difficult to reverse engineer ?)
From my experience from the delivery man pads (teeheehee) there is no way to enable a copy and paste. Also the displays are like old school hand held gaming devices from the 90's (you know the ones with pre-terminded shapes and patterns?) or palm-pre devices from around 2004. In other words the quality is really poor. So really can't print off a copy of the signature.
This leaves the only way to copy it would be with a human again, and that just poses the same problem that's always been there with signatures. What stops someone copying it from a peice of paper?
Bur re-reading what you have written I havn't really answered your questions.
I've always wondered if these can actually be considered as proof of delivery/payment/etc - in particular the ones on self-service checkouts in supermarkets. They aren't even checked against the signature on your card, so in theory, anyone could steal/find your card, purposefully destroy the chip, and then use the mag strip/signature?
What happens when you spot an erroneous £100 sainsburys bill, call up your bank and they say "well, you signed for it"?
And why is that so ? Surely the pads will produce output when you use them for capturing the signature. Typically the output will be sent via USB to a PC program. The question is - does it sent data that are already encrypted, or does it send plain data and the only thing that stops you from copy / pasting them is that there is no such function in the PC program (however the data are physically in memory of the PC as received from USB and could be stolen e.g. by some hacked USB driver or reverse engineering / hacking the program etc.)
While in courier service the signature may mean little to nothing ("squiggle") I am pretty sure that pads used in banks go into much more detail and they have security >= as paper + ink signatures. And I would really like to know how I can be sure that my signature can not be easily copy pasted to sign a document I never would have signed. (there has to be an explanation as otherwise banks couldn't use it)
Well when I use them it seems to actually record only about 1 line in 5 so it looks like random garbage anyway ... hence it isn't something I worry about ...
