Buying in the US
22 Nov 2004
London
Hello,
I'm thinking about getting either an iPad or a MacBook Air when I visit New York in a couple of weeks. The prices are much better over there.
First off - is there any disadvantage in getting an iPad over there? Will the UK people refuse to service it if it goes wrong?
If I get the MacBook, it will be my first Mac - so a big change for me! I noticed that on some friends' macs the @ and " symbols are according to the US key layout, so I was wondering if this was the normal layout for Macs in the UK. In other words - is there any difference in keyboard layouts if I bought an Air in the US as compared to just buying it in the UK?
Any other advice to a potential convert gratefully received...
Thanks!
My MBP has the " and @ keys the US way - bought it in the UK. Get used to it, not sure why they done it that way mind you. Presumably then it's the same layout in America..
Not sure about the warranty thing, question ALWAYS comes up though about it.
If you have AppleCare, it doesn't matter where in the world you bought it from, it's cheaper to buy it in the US but make sure you throw away the box, to avoid paying the customs charge. (I think.)
As for the " and @ keys being the US way, it's normal here.
Enter key is also different on USA keyboards.
Its often closer to the size and shape of the shift key.
Apple hardware is a weird mashup of ANSI and ISO UK. As mentioned, the UK machines have the shaped enter key that we're used to with ISO (just a bit skinnier) but the layout in regards to @ and " is ANSI. I imagine the US machines will have the ANSI enter key as POB mentions, which is on a single row and similar to what we're accustomed to with the shift keys. The difference then with the ANSI layout will be the position of the pipe and forward slash key | \ which will take up the position of where the top of the return key in ISO layout is.
I wouldn't worry too much about the layout. It's something you will become accustomed to very quickly and then switching between ANSI/ISO or Apples mash up isn't that difficult. Myself, I gave up using ISO at home years ago as I could get more variety of keyboards in ANSI layout. I can flip between ANSI and ISO no problem though when dealing with other peoples keyboards.
I'm probably picking up an iPhone 4s in New York in a few weeks.. much cheaper than in the the Uk for a sim free one.
Tax evasion is a criminal offence, I don't think you should be using this forum to advocate this in any way nor inciting others to do the same. Is saving a few bob really worth the risk?
Arrgh. Total dilemma: iPad or MacBook Air.
Not expecting much sympathy. Just sharing my dilemma.
Well if you watched BBC Click at the weekend they inferred in the tribute to Steve Jobs that the Air is considered to be something of an Apple failure unlike the iPad.
Does that count for buying anything in the USA? I was hoping to stack up on Mountain Dew if and when I visit.
What is the intended use? Surely either you need a laptop or you don't? I have a 13"/4GB RAM/256GB 2010 MacBook Air and would never have considered an iPad.
Well...
I'm interested in having a whirl on OSX and seeing if it fits with my life. I have a desktop PC up in my attic office, and coupled with the slow startup times and a demanding home life it's annoying to use.
I guess I need to decide if I just want to consume content or both create and consume content.
While that might technically be the case, you'd be a mug to declare it. There's practically no way they'd be to determine where and when you bought it. The risk is practically non-existent and a complete non issue.
@nikeair it's to do with the value of it, stocking up on mountain dew should be perfectly fine even if you do declare it (which in this case you should, it's obvious that you've bought it in the US). If you're going with some one, split the import allowance between you and whoever you go with.
Don't bother declaring any laptop/tablet/phone or any other device you buy because you'll just be paying a mug tax, they aren't going to know where you've bought what, and when.
Just make sure you bin the boxes and get an electronic receipt from Apple. It's not impossible that a customs chap might ask a few questions regarding your recent purchase of a laptop in the US that amazingly is the same as the one in your hand luggage. Very unlikely indeed, but why take the risk. Don't take the pee either by trying to bring back two laptops and 5 iphones, your just asking for trouble.
Well...
Yep I suppose the 4 second start up from sleep with W7 can't really match the 3 second start up from sleep with my iMac!
