Just spotted these, looks like a very tidy solution. Should be available in November.
"The newest EK-VGA Supreme HF Bridge Editon waterblock is designed for use with parallel flow EK-FC Bridge system. Say goodbye to the awkward tubing & fitting connection of multiple GPU blocks. EK's Bridge system is a proven flow interconnect system which has been used for years on EK-FC series waterblock. This very same system is now available for GPU only waterblock EK-VGA Supreme HF.
EK-VGA Supreme HF Bridge Edition fits on all EK-FC Bridge connectors but it is designed to work properly only with parallel flow versions.
The Acetal top portion of the waterblock will also be available for purchase separately. The waterblock top also feature two G1/4 threaded ports which allow for installation of the EK-PSC 13mm fittings and other types of (angled) barbs/fittings."
