Hi all,
Quick question:
I've got an indoor arial (One for all SV-9305) that I am using. The signal is that bad that evey single channel is messed up. Do you think there is a point to buy some sort of aerial signal booster and if yes what would you recommend?
Searched around but there are so many of them that makes it hard to choose one.
I'd liek to stay in price range from 10 - 30 quid. Is there anything you recommend I could plugin between my teli and aerial to get better signal?
Would SLx 27841R 2-Way Plug-in Aerial Amplifier be any good?
Cheers in advance,
V.
			Quick question:
Cheers in advance,
V.
