Lian Li Case Deals.... Mega limited stocks!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Get yourself a great bargain, very limited stocks.
Lian Li PC-V600FB Aluminium Case - Black @ £143.99 inc VAT
This high-quality, all-aluminum computer case sports a grated front-panel design, three cooling fans (two with LED lighting), lots of build space with hot swappable capabilities, multiple USB 3.0 ports, and all the anti-vibration and tool-less features enthusiasts know are the markings of a Lian Li design. In short, another solid PC chassis from the Taiwan-based company.
Chassis Cooling
Two, great looking, 120mm LED lit fans on the front-panel pull cool air into the case while one 120mm top-panel fan expels heated air at the back of the case. Directly below the PSU mount on the bottom of the case, a vent helps to bring in cool air and is protected by a washable air filter. Venting in the PCI brackets on the back-panel further aids thermal flow.
Build Space
Two HDD cages, using thumb-screws with rubber suspension for tool-less installations, hold up to five 3.5” SATA hot swappable HDDs and two 2.5” HDDs. To increase video card space to a maximum of 370mm, one of the HDD cages can be quickly and easily removed. At the back and bottom of the case, a standard PS/2 power supply unit mounts with anti-vibration features. Side-panel removal is also tool-less on Lian Li's PC-V600F along with two 5.25” ODD mounts on the front-panel. Being a mini tower, users can choose to mount an M-ATX or Mini-ITX motherboard. At the front edge of the top-panel users have easy access to the power and reset switches along with two USB 3.0 ports, one e-SATA port, and HD Audio ports.
The all-aluminum, PC-V600F weighs in at 5kg. Its dimensions are 190mm x 390mm x 470mm (W, H, D). Design features, like cable management clips and M/B thumb screws, alongside fantastic looks, like LED lit fans and a cool looking front-panel, combine with the massive build space of the PC-V600F to make this mini tower an excellent choice for consumers looking for a high-quality, all-aluminum, top of the line computer case.
- Case Type: Mini Tower Chassis
- Dimensions: (W) 190mm x (H) 390mm x (D) 470mm
- Front bezel Material: Aluminum
- Color: Black / Silver / Red / Black ( Internal Black )
- Side Panel: Aluminum
- Body Material: Aluminum
- Net Weight: 5KG
- 5.25" drive bay (External): 2
- HDD bay: 3.5” HDD (Sata hot swap) x 5 / 2.5” HDD x 2
- Expansion Slots: 4
- Motherboard: Micro-ATX / Mini-ITX
- System Fan (Front): 120mm LED Fan x 2
- System Fan (Top): 120mm Fan x 1
- System Fan (Rear): None
- I/O Ports: USB 3.0 x 2 / e-SATA x1 / HD Audio
- Maximum Video Card Size: 370mm
Was £169.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Lian Li PC-Z70 Diamond Series Full Tower Case - Black @ £219.98 inc VAT
nonl2br
One of the most popular cases in Lian Li’s vast range is the PC-A70F, renowned for its spacious interior, sleek finish and somewhat affordable pricing (compared to other Lian Li cases). Through the marriage of design between itself and the PC-B25F was born the PC-Z70. This is another case that complies to HTPX standards thanks to 11 expansion slots and a large depth. The most striking feature is its smooth plain façade with smoothly rounded edges on the side and angular corners at the top and bases. Interestingly, there are no intakes fans at the front.
<br><br>
- Case Type: Full Tower Chassis<br>
- Front bezel Material: Aluminum + Plastic<br>
- Color: Black / Silver<br>
- Side Panel: Aluminum<br>
- Body Material: Aluminum<br>
- 5.25" drive bay (External): 3<br>
- 3.5" drive bay (External): None<br>
- HDD bay: 3.5" HDD (Sata hot swap) x 9 / 2.5" HDD x 2<br>
- Expansion Slot: 11<br>
- Motherboard: HPTX / EATX / ATX / M-ATX<br>
- System Fan (Front): 120mm Fan x 3<br>
- System Fan (Top): 140mm Fan x 2<br>
- System Fan (Rear): 120mm Fan x 1<br>
- I/O Ports: USB 3.0 x 2 / USB 2.0 x 1 / e-SATA x 1 / HD Audio<br>
- Maximum Video Card Size: 390mm<br>
- Dimensions : (W) 220mm x (H) 600mm x (D) 592mm<br><br>
Was £249.99 Inc. VAT
Only £219.98 inc VAT.
ORDER NOW
Lian Li PC-Z60 Diamond Series Midi Tower Case - Black @ £143.99 inc VAT
nonl2br
The PC-Z70’s smaller brother is the PC-Z60. It has the same distinctive plain but stylish front fascia but internally, it is very different. The smaller size means that only 8 PCIe brackets are present at the back and the motherboard cable management holes aren’t as numerous or lined with rubber grommets. Instead of the front mounted HDD trays, the PC-Z60 welcomingly features side mounted trays and as such front intake fans that suck air from the side vents on the front aluminium panel.
<br><br>
- Case Type: Mid Tower Chassis<br>
- HDD bay: 3.5" HDD (Sata hot swap) x 6 / 2.5” HDD x 2<br>
- Expansion Slot: 8<br>
- Motherboard: ATX / Micro-ATX / Mini-ITX<br>
- System Fan (Front): 120mm Fan x 2<br>
- System Fan (Top): 140mm Fan x 1<br>
- Maximum Video Card Size: 305mm<br>
- Dimensions : (W) 210mm x (H) 472mm x (D) 480mm<br><br><br>
<iframe width="425" height="349" src="
" frameborder="0" allowfullscreen></iframe>
Was £179.99 Inc. VAT
ORDER NOW
Lian Li PC-V2120X Aluminium Full Tower Case - All Black @ £319.99 inc VAT
The new PC-V2120 is a full-tower case, which is ideal for the latest graphic cards in combination with the best thermal dynamics. Especially in the advent of adding in new graphics cards, equipped with 11 PCI slots, which can hold three or more graphics cards, supports Crossfire and SLI.
PC-V2120 has hair-line brush anodized aluminum finishing. Huge internal space fits HPTX motherboard (have to remove one 140mm fan with HPTX M/B), and graphics card, which can up to 335mm long, and there are room for 13 hard drivers. There are 3 x 140mm and 1 x 120mm cooling fans to cool the system down, and a lot of internal space for liquid cooling system. It is an ideal for gamer and pro user!
The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent. The new 5.25” bay tool-less mounting incorporates a mounting bar equipped with rubber padding. After closing the mounting bar, the rubber pad pushes and holds the 5.25” device in position to both secure and absorb vibration from the device. There are noise reduction foam on the internal side of the side panel to reduce the noise level and the vibration.
There are three of 140mm fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast. There is a 120mm exhaust fan at the rear to draw the hot air out, and improve the air flow inside the chassis. On the front of the case there is a fan controller so the user can adjust the fan speed to get the best balance between silence and cooling. There are vents on the PCI slots to provide extra cooling to the graphics card.
- All Black Interior
- Dimensions: (W) 235mm x (H) 635mm x (D) 630mm
- 5.25" drive bay (External): 5
- 3.5" drive bay (Internal): 10 + 3 (Using 5.25-inch Bays x 3 )
- Motherboard: EATX / ATX / M-ATX / HPTX
- System Fan (Front): 140mm Fan x 3 & 120mm Fan x 1
- System Fan (Top): 120mm Fan Hole x 3 (Fan not included)
- I/O Ports: USB3.0 x 4 / e-SATA x 1 / HD Audio
- Maximum Video Card Size: 360mm
- 2.5" drive bay (Internal): 2 + 2 (Using one 3.5-inch bay for 2.5-inch HDDs converter)
Was £399.98 Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Lian Li PC-V2120B Aluminium Full Tower Case - Black @ £299.99 inc VAT
Was £369.98 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Lian Li PC-Q11R Aluminium Mini-ITX Cube Case - Red @ £79.99 inc VAT
The Mini-Q PC-Q11 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q11 with rounded edges fit with interior decoration easily. The hair-lined anodized aluminum exterior combined with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q11 is to be as simple as possible, the exterior of the case is also the structure of the chassis.
- Dimensions: (W) 200mm x (H) 326mm x (D) 260mm
- 5.25" drive bay (External): 1
- 3.5" drive bay (Internal): 3.5-Inch HDD x2 & 2.5-Inch HDD x2
- Expansion Slot: 2
- Motherboard: Mini ITX / Mini DTX
- System Fan (Front): 140mm Fan x 1
- System Fan (Top): None
- I/O Ports: USB3.0 x 2 / HD Audio
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Lian Li PC-Q06R Mini-ITX Aluminium Case / Test Bench - Red @ £44.99 inc VAT
PC-Q06 is a Mini-ITX TEST BENCH system, it supports standard Mini-ITX motherboards on the top, depending on your needs, it also supports ATX / M-ATX motherboard tray (Optional) for your system.
The clean shape of PC-Q06 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of PC-Q06 is to be as simple as possible, the exterior of the case is also the structure of the chassis. Multi-media port connectors follow international specification standards, with one connector for easy installation. The Chassis is made of 1.5mm aluminum alloy panel, The thick and solid chassis has no vibration problem. To reduce the size of the PC-Q06, the side panel are secured with screws, it also reduce the vibration, and lower the noise level. There are vent holes at the bottom and the rear panels, allowing air to enter to cool the system down. PC-Q06 supports a single 3.5" HDD, simply un-do the screw, ideal for easy HDD installation and services. The Hard Fits at the top of the chassis underneath the external motherboard risers.
- Dimensions: (W) 205mm x (H) 210mm x (D) 250mm
- 5.25" drive bay: 1
- 3.5" drive bay: 1
- Motherboard: Mini-ITX (Option: ATX / M-ATX)
- System Fan (Front):None
- I/O Ports: USB2.0 x 2 / HD Audio
Was £59.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Lian Li PC-X900R Full Tower Aluminium Case - Red @ £309.98 inc VAT
The TYR PC-X900 is the case which functionality and style converge. Open the side panel with the tool-less latch, HDD racks, 5 x120mm silent intake fans with filter, top mounted multi-media I/O ports, and the graphics card holder have been redesigned – because when it comes to your comfort, every detail counts. The PC-X900 has two-heat zones designed to provide a better thermal solution and helps tidy up internal space. The new internal layout has the motherboard on middle level, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. To install the power supply unit, just slide the power supply unit throguh the opening at the rear of the case, and there are room for 180mm long power supply. This case features Lian Li patented Anti-virbation HDD cage, which allow user to fit seven 3.5" HDDs. It is easy to use, no tools required, simply using the special thumb screws to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage. There are three of 120mm blue LED fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
In the upper zone, there is a 120mm exhaust blue LED fan at the rear to draw the hot air out, and improve the air flow inside the chassis. In the lower zone, there is a 120mm exhaust blue LED fan at the rear to draw the hot air out, and improve the air flow inside the chassis.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports x 4, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 230mm x (H) 598mm x (D) 388mm
- Side Panel: Transparent Side Panel
- 5.25" drive bay: 3
- 3.5" drive bay: 8
- Motherboard: ATX / M-ATX
- System Fan (Front): 120mm Red LED Fan x 3
- System Fan (Rear): 120mm Red LED Fan x 2
Was £349.99 Inc. VAT
Only £309.98 inc VAT.
ORDER NOW
Lian Li PC-X2000F Aluminium Full-Tower Case - Black @ £349.99 inc VAT
The TYR PC-X2000F is the case which functionality and style converge.Open the side panel with the tool-less latch, HDD racks, 5 x140mm silent intake fans with filter, top mounted multi-media I/O ports, and the graphics card holder have been redesigned – because when it comes to your comfort, every detail counts. The PC-X2000F has two-heat zones design to have better thermal solution and tidy up internal space. The new internal layout has the motherboard on middle level, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. To install the power supply unit, just slide the power supply unit throguh the opening at the rear of the case. The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent. TYR PC-X2000F features Lian Li SAS hot swap HDD cage, which allow user to fit seven of 3.5" HDDs. It is easy to use, no tool required, there are aluminum handles for HDDs, allow user to install or remove HDD easier. There are three of 140mm fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
- Dimensions: (W) 240mm x (H) 695mm x (D) 442mm
- 5.25" drive bay: 4
- 3.5" drive bay (Internal): 7(SAS Hot Swap)
- Motherboard: E-ATX / ATX / Mirco-ATX
- System Fan (Rear): 140mm Fan x 2
- I/O Ports: USB3.0 x 4 / e-SATA x1 / HD Audio
Was £409.99 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Lian Li PC-8FIR Aluminium Midi Tower Case - Red @ £159.98 inc VAT
The look of PC-8FI has a minimalism style. The front panel design is a combination of art and functionality, with the hair line brushed and anodized aluminum finish to make this the ultimate high-end chassis. The new internal layout has the motherboard on top of the power supply unit, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. The power supply unit at the bottom of the case is cooled with fresh cool air directly from the outside of the case, instead of pre-heated air from within. This will bring down the core temperatures and extend the lifespan of the PSU significantly. The PC-8FI is a Mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. All the internal installation can be done without tools, and is easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots this chassis can hold up to four graphics cards, supporting CrossfireX™ and 4-way SLI™.
The PC-8FI is equipped with large cooling fans, with low RPM, which still provide enough air flow to cool down the hardware adequately. The front two 120mm intakes red LED fan runs at 1200RPM. The rear 120mm exhaust fan just next to the CPU, it can remove the hot air out fast and silently. There are vents on the PCI slots, provids extra cooling to graphics card.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 210mm x (H) 460mm x (D) 490mm
- Front bezel Material:Aluminum
- 3.5" drive bay (External): 1(use one 5.25 to 3.5 converter)
- 3.5" drive bay (Internal): 6
- System Fan (Front): 120mm Red LED Fan x 2 (1200RPM)
- System Fan (Top): 140mm Fan Hole x 1 (Fan not included)
- System Fan (Rear): 120mm Red LED Fan x 1 (1200RPM)
- I/O Ports: USB3.0 x 2 / e-SATA x1 / HD Audio
Was £199.99 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
tempted by either of the full reds!! maybe by price point the Lian Li PC-8FIR rather than the Lian Li PC-X900R but they both look awesome!! Shall consider for my build!
The X900 is a fantastic case. One of my only true proper case loves. I bought the black one from here a while ago and still get goosebumps when I think about it.
It's pretty much perfect for air cooling with powerful direct airflow (on stock), bagloads of space for cable management, a built in very high quality fan controller, and lots of HDD space. Also has a tiny footprint.
Very happy Lian Li owner as well, (A70F), though the PC-V2120X with the all black interior is beautiful.
