drunkenmaster i fail to see how you can possibly attempt to spin the fact that this chip is an absolute failure in almost every department. You seem to have an extremely optimistic appraisal of a very bleak reality...
YOu do know I linked to the anandtech review, and that you can't read?
The gaming benchmarks really are irrelevant, when did you last use a top end gpu for low resolution, you simply don't, I do not care how it does in situations I don't come across, that NO ONE comes across, but the ones I do.
Do you realise the 8150 is ahead in MANY of those benchmarks, do you realise at on limit resolution gpu limited gaming bulldozer is beating the 2500k. Do you realise that pass 1/2 of rendering, pass 2 is the MUCH SLOWER one that takes much longer that does a lot more work, being 30% faster in pass 2, and 30% slower in pass 1, would make the entire encode all together take significantly less time on the CPU that is faster on pass 2...... thats Bulldozer.
Cinebench, Bulldozer loses in single thread, it matches the 2500k in multi in the OLD version and it BEATS it in the newer version........ and its still an out dated benchmark. Seriously, who would run a rendering program single threaded, no one, thats your answer, its a synthetic test, in the real world you'd run multithread, where Bulldozer is faster, again.
How am I spinning, LOOK AT THE NUMBERS.
There are 15 benchmarks on that page, the 8150 is ahead of the 2500k in 8 of them.
Its faster than the 2500k in more than half the tests......... where am I spinning?
Damn it. My prediction of £220 is off by 2p
http://www.overclockers.co.uk/showproduct.php?prodid=CP-311-AM&groupid=701&catid=6&subcat=1942
At least I predicted the ocuk product code (CP-311-AM) correctly![]()
You do realize it's from the same website. Thus more comparable. You do realize that in the vast majority of benchmarks, the 2500k annihilation the 8150.
They compare single threads to give in indication of efficiency. Of which BD has none. Even old P2's beat it. BD is only good for heavily threaded apps and even then it only beats the 2500k by a small margin. Against the 2600k it doesn't stand a chance.
Even the 2500k at stock trumps the 8150 @ 4.5Ghz in tests. Not even the hardest of AMD fanboys can defend Bulldozer. Not to mention consuming over 500W when OC'd to 4.8Ghz.
Lets face it, BD fails completely.
Is the 1100t not just a 1090t that amd have oc'ed slightly?
I am no expert and don't know but it just makes sense to me to buy the 1090t as they will probably oc to the same core speed?
Bought!![]()
Just that 1100T are guaranteed to be newer stock with later steppings perhaps. But I suspect you're right.
