Torque to Weight ratio... bonkers?
22 Oct 2004
Berkland
So I was talking to a mate on email about cars, and he came up with the quote below. So is it laughable or something to take note of?
To see how fast it'll be in the real world you need to divide torque by weight.
so mine is 400/1720 = 0.232
350z (assuming you get the newer 295bph one) is: 353/1534 = 0.230
but that alone doesnt give the hole picture as the cars get above 0.21 the variation in the figures makes less of a difference. So in theory they should be identical. Even if one of them was 0.25 they would be very close...... but my car is turbo'd so all it's power is low down, from 2000rpm-5000rpm the power is a straight line... all 280bhp. The 350z will need to be rev'd and will lose our lots during gear changes.
I did **** loads of research before buying my car, because i bought my previous one on peak bhp and was always disappointed with how fast it was. This time wrote an app to download all of the parkers database so I could compare the cars on a spreadsheet.... i can;t find it at the mo, otherwise i'd send it.
To put it in perspective, i fluffed a gearchange on my car overtaking a 730d (my car has loads more power), but because of his turbo and torque (and he decided to be a ******) his car ended up pulling back past me.
To be fair though, once you get above 250bhp it all get a bit dangerous to mess about racing other cars of similar power, as you get up to silly speeds way too fast, so I don't do it ever now..... so the differences between a 350z vs saab turbox doesnt really matter.
If you don't use your car much you should get something fast/ practical. I wish you could drive mine before you bought, you'd def end up wanting a car with a turbo.
lolMate?
Had he taking into consideration gear ratios before making this awesome spreadsheet.
Him fluffing a gearchange is not the fault of the car, and purely down to the driver. A Mondeo 2.2TDI has similar torque to a Ferrari so in his mind a Mondeo would beat a Ferrari? You work that one out.
lolMate?
So his car...
162bhp per tonne
232ft/lb torque per tonne
350z (his figures i dunno if they are correct)
192bhp per tonne
230ft/lb torque per tonne
Is he saying his (i assume by the figures) diesel is quicker than a 350z? :confused:
So his car...
162bhp per tonne
192bhp per tonne
His is a petrol. A saab 93 turbox from what i remember.
I thought it might get a couple of laughs.
Utter crap. My car has twice the torks of a CTR but the Honda would beat me to 60 by a second and a half.
Torque isn't everything. Neither is lots of revs. You need a good balance of both, and then you can start taking weight into consideration.
Im confused now :S I always thought torque/ton was more important than bhp/ton hence why an XJ220 can out drag a Zonda despite having less power and more weight, like that old racing champion said hp sells cars torque wins races :S
Of course, which is why F1 engines rev to 18,000rpm with next to no torque but make 700bhp instead of making 2000ft/lbs of torque and revving to 300rpm like a ship engine...
Tractors have a lot of torque.
Out drag as in acceleration or top speed.
Top Speed like that is all about the aero drag, aero drag is overcome by power as you need to apply the work at a decent rate and the definition of power is workrate.
hum, without running to wiki bhp is a product of torque and rotational speed.
If designing any vehicle engine you would look first at the weight of the thing, then decide on how the engine delivered it's power at a guess.... for 44tons you would need monster torque and low rpm (extreme rotational force), hence a relative low bhp and inability to compete with current F1 cars.
As you push rpm up even with a slowly reducing torque figure bhp also leaps up, which at another guess would explain how a high reving low torque VTEC engine would destroy a run of the mill torque laden diesel runabout
Just some guess work, maybe I'm right, maybe wrong :( ....on second thoughts it's too much to think about, but the whole ops mates torque per ton argument is way too funny even if I can't prove him wrong
