2 mid-range cards or 1 high-end card?
9 Apr 2006
I'm new to Sli/Crossfire and I was going to treat myself to a single GTX 580 but have since been looking at getting 2 mid range cards instead if it means saving money and still getting the same (or better) performance.
A few questions before I make a purchase.
1. Do games benefit from Crossfire/Sli other than FPS?
2. Would I notice a graphical difference in Sli/Crossfire over a single card? (Is a single GTX 580 capable of producing better graphics than 2 x 6950's?)
3. Which are the best 2 mid-range cards on the market at the moment for SLi or Crossfire that will be capable of running maximum/ultra settings in games, specifically Battlefield 3?
Always better to go for one single high performance card (if there is one available) than two lesser cards. A single card will run cooler, probably use less power and create less heat, and you won't have any of the headaches of multi-gpu drivers (e.g. lack of optimisation).
A GTX580 is sufficient at 1920x1200, but if you're running higher than that, CrossFire or SLi might be a good option.
Personally I think this usually boils down to budget at time of purchase as two cards lets you split the cost over a period of time. I went crossfire 5850s because they were madly reduced on OCUK when I was upgrading.
I'd also like to point out that BF3 does bring any single-GPU card to its knees. :p
This basically.
Less power consumption and heat paired with less driver issues, unless you play some computer breaking game at a silly resolution the extra few frames aren't worth it in my opinion.
Take it coming from someone who's had SLI in the past and is currently using crossfire.
I guess I didn't word my post to well above :rolleyes: so lets try again.
Nobody really knows how well BF3 will play on a single gtx 580, other than the developers right now. Yes it will give a single gtx 580 a hard time. But I shouldn't think it will be unplayable on a single card.
Both SLI and a single card have there pro's and con's. SLI would make you more future proof for up and coming games like BF3 for sure.
You will get a bit more heat and noise with SLI, but as long as you have good cooling in your case that should lessen it a bit.
so once again...
1: yes more fps = better image quality, which should have been obvious.
2: yes you would notice a graphical difference using SLI over a single card using both SLI or Crossfire. Again more fps will allow you to use better image quality if needed.
3: It all depends if you prefer AMD or Nvidia and how much you are willing to spend. Something like this http://www.overclockers.co.uk/showproduct.php?prodid=GX-150-EA&groupid=701&catid=1914&subcat=1010 or this http://www.overclockers.co.uk/showproduct.php?prodid=GX-147-OK&groupid=701&catid=56&subcat=1752
No one knows your budget, so you could buy two GTX 580's even, then you should be able to play everything you can through at your system. :D
Thanks for the replies. I'm currently running a resolution of 1680x1050 but will be upgrading to a 24" monitor soon at 1920x1200.
I think I've decided on a single card as it will be cheaper to run and create less heat as reflux has said.
I think it's a good choice to pick a single powerful card for now.
Then if you decided to upgrade to SLI in the future, you can then do so.
I just noticed you new sig, and that power supply might be pushing it a bit for two cards in SLI. So that might need to be upgraded also, if you were to choose SLI.
