Can anybody explain to me why the FX-8150 8 cores can't beat the 2600k 4 cores and 4 threads. It frequencies are much higher, is it just the architecture?
Their choice of game tests is a tad naff, lol at anandnoob
i've bought a 8150 so i can test it myself, also i do video encode so hopefully it'll be better than my 1090t in that.
Their choice of game tests is a tad naff, lol at anandnoob![]()
@noob.That's exactly what we're all wondering.
It's simply because code is not optimised for BD.
This is the part i quite don't understand. All windows will see is a processor with 8 available cores. Just the same as an i7 2600k. So any mutlithreaded app will just see the same amount of cores.
Now im assuming by "new windows code" that AMD want module/core load balancing code within windows to assist with the processing efficiency of bulldozer?
Far as I understand the Windows 7 issue is related to not shutting down cores at correct time, so the CPU is using more power that it should otherwise.
The issue with performance is due to code not been compiled for Bulldozer, other words code is not optimised for Bulldozer.
Visual Studio 2010 Service Pack 1 was released in March and had support for Bulldozer, so anything compiled with this should perform quite well. However to get from a developers desk, to an actual release can take a year or even longer. It's not even a quick task of re-compiling code, as all applications must go into testing and release cycles, this all takes time.
The issue is vast majority of code is not compiled with BD in mind, and software will need either an update, or wait for next release before it runs correctly.
I honestly think BD is a good chip, but will take at least a year before mainstream applications/games are compiled for it, best hope is patches are released. Even then there will be applications / games / drivers / modules that stay in use for years and never optimised for BD. Just for a moment think of the 1000's of dll's that form Windows 7 and drivers, most of these will never be re-compiled for BD.
http://www.anandtech.com/bench/Product/288?vs=434
It seems even the 2500K beats it in a few video editing/encoding software....
