- 19 Feb 2007
- Northampton
So apart from the top end bulldozer having 2 more cores and having a higher stock clock, how much of a performance difference will there actually be between an 1100T and a 8150 ?
1100T vs 8150
Overall both CPUs trade blows against each other, sometimes the 8150 is better, sometimes the 1100T is better.
1100T vs 8150
Overall in those tests i think the 1100T only beat it 1 or 2 times, but yeah still not good enough.
Architecture wise, for gaming the 8150 is SLOWER clock for clock than the 1100T. Look at the following...the 8150 at 4.8GHz only MATCH the performance of the 1100T at 4.2GHz:So apart from the top end bulldozer having 2 more cores and having a higher stock clock, how much of a performance difference will there actually be between an 1100T and a 8150 ?
That's a very good point actually, I bet Llano's IPC will be rather nice in comparison. I've not looked into Llano's architecture much though, are there any significant layout changes or cache differences compared to Deneb?anyone did a comparison between the FX quad-cores and Llano based quad, would be interesting to see Bulldozer vs. K10.5+
on another note, Phenom II isn't a bad architecture at all, its just slowed down a slow CPU-NB and slow L3 cache, if AMD buffed up the northbridge speeds and sorted out the cache Phenom wouldn't be that far behind the current Intel offerings. did a run a while ago with my Phenom with tighter memory settings and overclocked CPU-NB (whilst keeping the CPU frequency the same) and there was possibly ~15% improvement compared to stock settings, even though the processor was running at the default frequency, this is the sort of thing that annoys me about AMD at its current state, there are improvements to be had in K10.5 just seems as though they can't be bothered to do it!
Not sure about specifics but from what I remember, Llano's IPC is very similar to that of the Phenom II, despite having no L3 cache. So there's definitely an improvement over Athlon II.That's a very good point actually, I bet Llano's IPC will be rather nice in comparison. I've not looked into Llano's architecture much though, are there any significant layout changes or cache differences compared to Deneb?
