Just purchased a TP-Link AV200 200Mbps starter kit from ocuk to replace my wifi adatper. If i had to use one word for price, ease of setup and connection. It would be Awesome
Unboxing pics
I honestly didnt expect 2 Ethernet cables!
= good
= no no < idiot proof instructions?!?
My thoughts.
I have been using a wifi adapter for my desktop pc in my room for a good 6 months. Every now and then i will get a drop out and i would have to disconnect and reconnect the adaptor. Sometimes that didnt work, i had to find some where else in usb length that gave a stronger signal. I hated this very much. So i bought these beasts!
At first i was sceptical about internet through power lines. I read into it and read reviews. They seemed to be worth £30! After unboxing i did a quick read through the instructions. Seems it was as simple as plug and connect. I did this and it worked 50%! I was connecting to my routers network but not connecting to the internet. After reading again, if this was the case it means the adapters would need to be paired. So i held the button in for 5 secs, ran down stairs and held the other one in for 5 secs. I waited 5 minutes before returning to my pc and boom there was internet! I expected to play around with settings and that but really...it does what it says, plug and play! (or plug and surf?)
With my wireless adapter i would just get 3mbps on speedtest.net. Here is what i have now
Honestly i couldn't be happier! My router is in the middle of my house, i have no holes in the floor routing wires, i dont have to deal with connection drops. I can use my laptop anywhere in my house, even out in the garden now that i have my router in the middle of the house. They also work even when connected to a surgeprotector!
If you are interested in these and would like to see some sort of tests, feel free to ask and i will do them for you
so far since receiving these this morning there has been no connection drops!
In conclusion, i recommend these to people who have a desktop pc far away from there router, and dont want to run extensions! you get the benefit of getting your full internet speed without the hassle of wireless. Yes wireless can be good but thats only if you buy a good adapter
not everyone likes a usb stick sticking out there case all the time or a weird looking device sitting on there desk. Or having to use up a precious pci slot for a wifi card
If your pc is in front of your sockets, well you will never see any wires!
Unboxing pics
= good
= no no < idiot proof instructions?!? My thoughts.
so far since receiving these this morning there has been no connection drops!In conclusion, i recommend these to people who have a desktop pc far away from there router, and dont want to run extensions! you get the benefit of getting your full internet speed without the hassle of wireless. Yes wireless can be good but thats only if you buy a good adapter
