AFAIK it actually takes a naked flame to ignite petrol, the glowing end of a cigarette can not do this, correct me if i'm wrong though![]()
It would depend on how hot the end of the cigarette was, surely.
You're never told how to open the emergency exit, there is just a sign on the door saying how to do it (from someone who sat next to one around 48hours ago).
On a kind of similar note... Aircraft doors... Can you open them whilst in the air (specifically via emergency release)? If so would that not be an easy way of taking down a plane/killing lots of passengers?
Its due to the possibility of the camera flying around the cabin and causing injury should the landing/take off be rough. Seems to be no consistancy to it tho, sometimes on the smaller jets I've been on i.e. Bristol<>Amsterdam FAs have been telling everyone to stow phones, cameras even drinks sometimes, other times they've not bothered.
Quick calculation,
A 767 usually keeps the cabin pressure at that of 2,100m (785mbar) while cruising at 12,000m (193mbar), meaning the interior of the cabin is 592mbar higher in pressure than the outside.
This roughly equates to an outward-pressure of 8.6 pounds per square inch.
Now, the size of the entry-doors on a 767 is roughly 42" x 74", giving a total surface area of roughly 3,108 Square inches, meaning that the total force required to overcome the cabin pressure and retract the doors for opening is 26,728.8 pounds, or more than twelve tonnes![]()
Quick calculation,
Quick calculation,
